Scratch Build – In Progress :Schlongboard: Sk8ter Mod
Discussion in 'Project Logs' started by Fozzy, 26 Jul 2011.
  1. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    This is my first mod I've posted in a while. I've been MIA in the modding community due to frequent moves so long term modding has been largely unsuccessful all though I may have a new case modding coming in the near future.
    This, however, is not a case mod. Rather it is a skateboard mod. I'm posting it here because I think people will enjoy it.
    Schlongboard: A skateboard with repositioned trucks that lowers the board and de-radius's the trucks adding stability at higher speeds.
    Lets get started.
    The Victim
    [​IMG][/IMG]
    This is a Double Impact Skateboard with a layer of carbon and 2 layers of wood reinforced with carbon. This deck is extremely strong, making it a good candidate for this mod.
    And this is what makes it no bueno for skateboarding
    [​IMG][/IMG]
    I've started by taping off the board to have a guide for repositioning the trucks. Because of the complex curves of the board, without a jig, I think this is the best way to operate.
    [​IMG][/IMG]
    As you can see here I used the risers as a guide for the tape, then I was able to slide the trucks up and down to drill the holes.
    [​IMG][/IMG]
    Next I dismantled one of the trucks to use as a drill guide
    [​IMG][/IMG]
    Then I clamped the truck down
    [​IMG][/IMG]
    Drilled out the holes
    [​IMG][/IMG]
    And one truck mounted
    [​IMG][/IMG]
    Both mounted
    [​IMG][/IMG]
    [​IMG][/IMG]
    I took the board down the street and it rode perfectly straight. This is the fourth scholngboard I've made and by far the best.
    Buuuuuuuuuuut.......
    It wouldn't be a very good mod If I left it like that.
    So off come the trucks and out come the bisquick box?????
    [​IMG][/IMG]
    Using the boz, risers, and screws, I made a template for my cutouts that could be flipped and hopefully be pretty precise.
    [​IMG][/IMG]
    [​IMG][/IMG]
    [​IMG][/IMG]
    And how the board sits now:
    [​IMG][/IMG]
    So stay tuned, there's much more to come and I've got about a month to complete it so this one will be short and sweet.
    Oops forgot one, here's a picture next to my skateboard for comparison.
    [​IMG][/IMG]
    See ya soon ; )
  2. Lance
    Lance Ender of discussions.
    6 May 2010
    Lol shlong.
    I have a longboard and I love it to bits. This looks like a great runabout.
  3. Gentleman_Dingo
    Gentleman_Dingo What's a Dremel?
    30 Aug 2007
    +rep. Mod the frickin' world.
  4. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Watercool it !
  5. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    neon/led lighting MUST have :)
    watercooling sk8 isn't REALY extreme... but putting singlestage on it?
  6. Fozzy
    25 Jan 2005
    Hmmmm maybe something like this to keep the bearings lubed at super fast speeds!
    More work last night on the schlong. Finally got to some cutting.
    Ran into a small snag
    But I think this should be fixable with some gorrilla glue and some clamps.
    Did a quick sand on all four corners with 150 grit but I think I need to go over it again after the crack is glued and clamped.
    Then I set it up on the trucks just to see how it looks.
    Stay tuned!
  7. Gentleman_Dingo
    30 Aug 2007
    Oh hell yeah! A nice long board with neon runner lights. That would be frickin' awesome here in Seattle in the early evening/night. You would cause accidents with all the rubber-neckers.
  8. Fozzy
    25 Jan 2005
    hey monkeyfun check out my location
  9. Gentleman_Dingo
    30 Aug 2007
    LOL, I thought this sounded like a project that would be close to home. You going to PAX? They're having a CPU Magazine sponsored Casemod contest! I'm trying to see if I can get my project done in time.
  10. Fozzy
    25 Jan 2005
    unfortunately not but that's a very good time haha
  11. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    seems like the design would put a lot of added stress on the curves, especially with the cutouts you made... have you used this design before?? how does it hold up to body weight?
  12. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I built my own longboard too :)
    If you want, I can post pictures in here. I don't want to derail/hijack your thread
