Electronics How many amps does an AA put out?
Discussion in 'Modding' started by Sloth, 13 Jan 2007.
  1. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    I had an idea for a future project (and hopefully the start of a company :hehe: ) to have some LEDs run off a couple of AA batteries, but I need to know:
    How many amps does a single AA battery put out?
  2. Snafu-X-
    Snafu-X- What's a Dremel?
    27 May 2005
    I looked around, and the consensus seems to be 2400mA for most AA batteries. Energizer claims a peak of 2700 on theirs.
  3. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Wow, thanks for the quick reply!
    Once quick other question, how many amps is 2400mA?
  4. Snafu-X-
    27 May 2005
    2.4 amps, but good look getting that for long from a AA battery.
  5. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    That's what I feared.. well, the lovable molex will come into play then
  6. Emon
    Emon What's a Dremel?
    14 Jun 2004
    If it's 2400mAh, then you would get 2400 mA for one hour. I'm not sure if mAh ratings take into account the voltage drop of the battery over time, etc.
  7. jakenbake
    jakenbake full duplex
    5 Jun 2005
    theres no way you get 2.4 amps from a AA battery. you get less from a 9volt when you stick it across your tounge. maybe 2.4 for like milliseconds...
  8. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    It's about 2400mAh for an AA, 1200mAh for a AAA and 550mAh for a PP3 battery.
    2400mAh means you can draw 2.4A for one hour, 1.2A for two horus, 0.6A for four hours etc...
  9. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    1C (that is: theoreticly discharging the battery in 1 hour) is not that high a discharge rate for a battery, even a consumer AA. But you wont get that long out of it, the capacity of a battery is measured at the 20 hour rate and the faster you discharge it the less energy you get out in total.
    I have to wonder about your electrical knowledge if you cant convert between mA and A
    Moriquendi
  10. ConKbot of Doom
    ConKbot of Doom Minimodder
    2 Jul 2003
    well for one, 9v batteries have a high internal resistance, and your saliva isnt that great of a conductor either, not compared to a copper wire. AA NiMH batteries can put out over 20A for short periods (seconds-a minute or two) Ive measured that myself...
  11. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    it depends of battery types. alkaline is (if i remember right) 1.5 volts but not much amps (cant remeber how much), while ni-cd\ni-hm only are 1.2 volt but comes in all ranges like 1200 mili-A to energizers 2700 mili-A.
  12. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    anyone wanna link a chart giving max current drain for standard cells?
    My google fails me.
  13. jakenbake
    5 Jun 2005
    well, damn. you learn something new every day.
  14. questioner
    questioner What's a Dremel?
    29 May 2008
    HELP
    battery info:
    question:
    The cam uses 9v at 300ma I believe (or so it says).
    Which item will last the longest for the cam (generally)?
    4 triple A
    4 double A
    1 9V
  15. Reverend_Jones
    Reverend_Jones Morte Nunquam Reget
    28 May 2008
    Battery Chart
  16. Krikkit
    21 Jan 2003
    The mAh can be thought of as the rate of energy it can provide for you. In the same application, you can eliminate the time component of it, and look at the numbers as energy. 4*2400 >> 550. :)
  17. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    I thought it was more a case of the amp hours. Could a battery rated 0.79Ah not put out a current of 7.9A for 1 hour?
  18. cpemma
    cpemma Ecky thump
    27 Nov 2001
    But 4*1.5V = 6V (or 4.8V with rechargeables) so 4 AA or AAA cells won't run the 9V cam at all. :lol:
    No. The battery datasheet may show a family of curves for different discharge rates, at the low and high current extremes life will be better and worse than the forecast from the Ah figure.
  19. Krikkit
    21 Jan 2003
    :lol: Read the bloody post why don't I?! :hehe:
  20. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    I'd be fricken amazed if any AA could put out 20a for even one second :eeek:
    Maybe a large battery pack of AA's could output 20a, maybe that's what is meant here :confused:
