Blogs My Experience With Jailbreaking So Far
Discussion in 'Article Discussion' started by Cutter McJ1b, 1 Feb 2010.
  1. Cutter McJ1b
    Cutter McJ1b Home-cut jibs at discount Prices
    18 Feb 2009
  2. bodkin
    bodkin Overheating
    8 Apr 2009
    One major problem I have noticed on both my 3G and 3GS is that jailborken phones are far less stable and much more prone to the broken keyboard problem
  3. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    very interesting the Bit have put this on their home page what are the moral / legal issues around jailbreaking as i bought an android specifically because it was a more open platform
  4. Xir
    Xir Modder
    26 Apr 2006
    ...are you sure it ALWAYS asks you before sending?
    (just my Windows-paranoia talking here)
    Xir
  5. Cutter McJ1b
    18 Feb 2009
    I jailbroke my new iPhone 3GS. It was the first time I'd plugged it in to my new PC. I got asked about Apps genius once, said no. I also turned off autosync. No problems at all so far.
  6. Cutter McJ1b
    18 Feb 2009
    Can't say I've had any issues with my keyboard...
  7. Combatus
    16 Feb 2009
    Err read paragraphs 7, 8, 9 and 10 :rolleyes:
  8. Anfield
    Anfield Multimodder
    15 Jan 2010
    So you have to "hack" a Iphone in order to be able to transfer files with drag and drop? lulz...
  9. wyx087
    15 Aug 2007
    SBsetttings: i can't imagine ANYONE without it!
    i won't recommend blackrain. it is jailbreak by fiddling with files through USB, with chances of messing up. use PwnageTool to create your own firmware, then use Apple's iTunes to write to the iPhone, nothing can go wrong :)
  10. yakyb
    10 Oct 2006
    how the **** did i miss that
  11. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
    Don't worry, it is a Monday ;)
  12. DeMoB
    DeMoB All of my Dremel wheels are broke!
    10 Jul 2008
    That's not really true now is it.
    If you're stuck with a tethered jailbreak with blackra1n, you'll still be stuck with a tethered jailbreak with pwnage tool too. It's not down to the program you use to jailbreak, but rather if you've got an iphone with the new bootrom hardware. Which I think that was any made after oct 09.
    As for anyone using the SBSettings with the default theme, do yourself a favour and grab the "Apple Congruency Black" theme for it. Looks as swish as the rest of the OS then. :D
    Dan
  13. wyx087
    15 Aug 2007
    sorry, i didn't mean tethered jailbreak, i mean messing with files through USB connection (hence confusion with the word "tether") creating an IPSW file and flashing the phone is as clean jailbreak as you can get.
  14. phuzz
    phuzz This is a title
    28 May 2004
    I jailbroke my work iPhone as soon as I got it (and uninstalled itunes as soon as it was activated).
    Still glad I don't have to use one as my daily phone though, without Cydia/Jailbreaking then it would be almost un-customisable.
  15. kenco_uk
    28 Nov 2003
    I'm biting! I just need to know a few things...
    I'm on o2 with the 3.1.2 phone firmware and 05.11 modem firmware. I don't want to unlock the carrier.
    Can I just use redsn0w 0.9.2?
    It says it requires a tethered reboot.. is that whenever the phone runs out of juice and reboots when it's got enough charge again? So I'd have to have it connected to a computer rather than the mains-usb adapter? And is that any computer or the one I ran redsn0w on?
    Can I still use itunes as normal? I.e. podcasts, purchases, apps?
    How do I uninstall it?
    What happens if I upgrade to Apple's 3.1.3 firmware? Anything I need to do/make sure of beforehand?
  16. Cutter McJ1b
    18 Feb 2009
    Sadly, I'm unsure about a lot of this stuff as jailbreaking is still very new to me and I don't want to misinform. Perhaps someone else can help?
    When I did it, I just plugged in my new iPhone and got stuck in.
  17. wyx087
    15 Aug 2007
    if you upgrade to new firmware, you'll loose jailbreak, so wait until the dev-team have gotten a jailbreak before upgrading.
    not sure about redsnow, i always use Pwnaget Tool which creates a custom firmware and there is no need to do a tethered reboot. best source and most reliable source for everything about jailbreaking: http://blog.iphone-dev.org/ (personally don't trust any other method of jailbreaking, that includes ZiPhone, blackra1n, redsnow.
  18. kenco_uk
    28 Nov 2003
    I'm under the impression that pwnagetool is specifically for mac and that the same team that developed it are those that have released the windows version called redsn0w. Looking at the tut for installing redsn0w, it has (c) iphone dev team on the installer.
    I can only find two 'Windows options' on iclarified - either redsn0w or BlackRa1n Link. BlackRa1n looks easier but there could be an issue with wifi suddenly not working (although for some people multiple resets or subjecting the rear of the iphone to freezing temperatures fixes it! - gps and youtube are fixable thru' Push It app) from what I read.
    edit - wtf, each of the custom ipsw files I try to d/l are iphone1,2_3.1.2_7D11_Restore.zip - extracting the zip gives me 3 .dmg files and all bloody sorts.
    ninja edit - ahh, I rename the file from .zip to .ipsw - correct? It's come up with the proper icon, at least!
  19. wyx087
    15 Aug 2007
    be careful, from the file name, it is for iPhone 3G, not 3GS.
    pwnage tool is reliable because it fiddles with the file system on your computer, and then the pre-jailbroken, custom made firmware is flashed to the phone through relatively more reliable itunes.
  20. |V| 4 L k i 3 R
    |V| 4 L k i 3 R Minimodder
    5 Jul 2002
    I've done it with Pwnage tool on my 3GS and with BlackRa1n on a 3G in order to get them on different carries while abroad. Both phones still work/sync flawlessly with iTunes.
Tags: Add Tags
