Peripherals Thinking of buying a 360 controller, but which one?
Discussion in 'Hardware' started by GeorgeStorm, 25 Nov 2013.
  1. GeorgeStorm
    16 Dec 2008
    Hey,
    As above, I'm considering getting a 360 controller to use with the PC (since I think they're meant to be the best?) for games such as the LEGO games, and maybe some others (racing ones for example).
    However there seem to be lots of different ones, so I was wondering if there are some known 'good' ones? Or ones to avoid?
    Thanks
  2. Lance
    Lance Ender of discussions.
    6 May 2010
    Do you already have an xbox? If so, get a wireless receiver, they're a bit rare these days, but mines amazing.
  3. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    I would just get a bog standard wired xbox controller (or a wireless one with the matching usb wireless dongle).
    They are the nuts and work out of the box with 99% of pad enabled games.
    Ive been using them for a few years now with no problems.
    Sent from my GT-I9505 using Tapatalk
  4. Williz
    Williz Minimodder
    9 Mar 2012
    XEOX, seriously buy one now. haha there's a wired and wireless variant. I bought two wireless ones and wouldn't get anything else, they have such a nice rubberized finish and can switch from xbox emu mode to direct input at the slide of a button which is handy. They charge over mini usb as well so no having to faff with batteries, I think I charged them once in the last month or so and they're still playing fine.
  5. GeorgeStorm
    16 Dec 2008
    I don't.
    Do you mean the official Microsoft one?
    Do you mean the speedlink xeox? It seems to be the same price as the official models so surely it would be safer to go for one of them?
    One of the main things I wanted to know was whether I should buy an official model, or whether some of the cheaper 3rd party ones were just as good.
  6. jinq-sea
    15 Oct 2012
    I've got a wired one that I rarely use (spare for the 360 too though, right) and a wireless one plus a wireless dongle. Both are bloody excellent - well worth it :)
    EDIT: Both are official Microsoft, as is the USB receiver
  7. Shirty
    18 Apr 1982
    I has an official wireless one and it worked flawlessly. I'd recommend it unless it's either too expensive or lacking added functionality.
  8. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    my bog standard wired 360 pad is the one I use the most (and I'm 1337 pad gamer - due to lazyness and desire to not sit upright properly with mouse and keyboard). I bought one of those expensive razer ones thinking it would trump it, but I no likey it, gave it to my housemate ages ago.
  9. GeorgeK
    18 Sep 2010
    Another +1 for the official xbox wired controller - just plug and play and it's the best controller in terms of feel in my opinion. I use it regularly for non-fps games (Just Cause 2, Saints Row IV and the Batman games are best with a controller imo)
  10. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    Don't buy the cheapie madcatz wired controller, I make do with that on the PC but it sucks.
  11. qualalol
    qualalol What's a Dremel?
    24 Aug 2011
    I have both wired and wireless PC Xbox controllers:
    Wired: fairly standard, plug in and go, no complicated stuff to watch out for.
    Wireless: make sure you specifically by the XBox 360 Wireless PC controller -- I accidentally bought the non-pc wireless controller (I knew about both versions, but somehow picked the wrong one when I decided to order...)-- it's the same controller but comes without the wireless receiver which the pc version comes with (you can buy the receiver separately though, albeit unpackaged/only inofficially available, and slightly more expensive than buying in one package).
    I've not actually had much of a chance to use the wireless one since buying, however I have bought the play and charge kit, which is a rechargeable battery + a cable which you can plug in the back to recharge the battery (also usable when playing). I've never actually tested the default non-rechargeable batteries so can't say how long they last, but as mentioned haven't tested the rechargeable one much either.
    Overall the wired will be much cheaper and less hassle though.
  12. jinq-sea
    15 Oct 2012
    I bought my wireless receiver from game about six or seven years ago - I'm not sure they did it bundled with the controller back then...!
    It's still going strong though - if you hate wires, track one down! Amazon is probably your friend...
  13. Porkins' Wingman
    Porkins' Wingman Can't touch this
    23 Feb 2008
    I've got two wired 360 controllers. Can't fault them apart from the fact that the sheer amount of cable, while potentially useful, is generally a nuisance. I don't use them enough to justify the extra (I think it's extra) for the wireless versions, but kinda wish I had.
  14. rollo
    rollo Modder
    16 May 2008
    Standard wired official controller you can pick them up cheap in second hand stores (£5-£10) not alot of point in spending more on others.
  15. GeorgeStorm
    16 Dec 2008
    Thanks, I think I'll just go for a wired official one, but I'll do a bit of googling about the wireless models.
    The only reason I asked about 3rd pary controllers was because they are cheaper, I wasn't planning on buying a more expensive 3rd party controller.
  16. Cei
    Cei pew pew pew
    22 Mar 2008
    We have a wired 360 controller and a wireless one (both official Microsoft) and they're the best pads you can buy to be honest. I personally prefer the wireless one as it is one less thing to trip over, but it is more expensive and offers no functionality or performance benefit beyond the lack of cable.
  17. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Expensive 3rd party ones don't make you l33t unfortunately, official ones are the ones to get.
  18. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I'm with pretty much everyone else. Get an official controller. Got the wired one myself and it works perfectly.
  19. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    I use a wired Afterglow Xbox 360 controller. Clear case with green LEDs that thankfully can be switched off. It was £15 from ASDA and it's one of the nicest controllers I have ever used. I like it more than the official Microsoft controller.
  20. Dead Pixel
    Dead Pixel What's a Dremel?
    14 Nov 2013
    +1 For the official wired 360 controller. I've had one a few years now and never had any problem with it. It's very comfortable to hold.
    I wonder would there be much difference in latency between the wired and wireless controllers?
