Other Firefox Speedup tip
Discussion in 'Software' started by deathtaker27, 1 Sep 2010.
  1. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    If you have broadband (as most of us do), you can use something called pipe-lining to speed up firefox. This allows multiple objects to be downloaded at once. below is everything, do at your own risk :)
    Here's what you need to do:
    * Type "about:config" into the address bar and hit return (you probably want to do this in a seperate tab so you can check back here).
    * Type "network.http" in the filter field, and change the following settings (double-click on them to change them):
    * Set "network.http.pipelining" to "true"
    * Set "network.http.proxy.pipelining' to "true"
    * Set "network.http.pipelining.maxrequests" to a number like 30. This will allow it to make 30 requests at once.
    Right click a blank space in the window and Create a new integer value called "nglayout.initialpaint.delay" and set it to "0".
    Right Click a blank space in the window and create a new Boolean Then enter "content.interrupt.parsing" in the New boolean value pop-up window and click OK, then set this to "true" when prompted.
    Restart your browser, it should be noticeably faster...
    Enjoy faster forums guys ;)
    matt..., andrewbarke, Booga and 15 others like this.
  2. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I heard about these settings before. Here's hoping they make it a proper system in Firefox 4.
  3. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    we can hope, but before that we can just do it ourselves.
  4. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    lol now it's too fast :p
    Thanks.
  5. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    try nglayout.initialpaint.delay == 5
    it's not so blunt drawing the screen as it loads :D
  6. Nexxo
    23 Oct 2001
    Wow. Faaaaast!!! :)
  7. Prometheus
    Prometheus Minimodder
    26 Jun 2004
    Wow, thanks. Have some rep :)
  8. Pookeyhead
    30 Jan 2004
    That made no difference here.
    [edit]
    No... wait... Hmm.. maybe.
    [edit of edit]
    Indeed it is. Rep given
  9. freshsandwiches
    freshsandwiches Can I do science to it?
    9 Aug 2009
    Nice one thanks :)
  10. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    thats awesome rep coming your way
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    wooooooooooooah
  12. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    sorry thats a side effect ;)
  13. GoodBytes
    20 Jan 2007
    Niiiiiiice!
    +rep
  14. murraynt
    murraynt Modder
    6 Jun 2009
    It there any point in doing this for fire fox 4 BETA?
  15. GoodBytes
    20 Jan 2007
    Firefox 4 is already fast... I did it, and I saw a a bit of a speed increase (visually), so it's welcome change, and I like it.
  16. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Worked for me, rep given. :thumb:
  17. murraynt
    murraynt Modder
    6 Jun 2009
    Ill have ago of it so.
    Thanks.
  18. murraynt
    murraynt Modder
    6 Jun 2009
    It worked:D
    Ill follow the example and give some rep. :thumb:
  19. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    I've applied it at work and at home.
    Not much different at work, although I do have a direct link onto a proper 50mb link to the internet (proper as in not cable, its a business leased line, fiber with an ethernet convertor on the end :baby:), and I've yet to test it properly at home, but I will!
  20. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    damn, much faster on 3.6.8, running on a 30Mbps down, 5Mbps up cable line
