just got ati tool for my 9800pro (bored) and i heard that some 128 9800's can have the r360 core - when i check the settings - where it says core - is that what the physical card says it is or what bios says it is???
ati tool just assumes if you have a 9800pro its an R350 core, and if you have a 9800xt its a r360 core.. Taking off the cooler and having a look is the best way to find out
Yeah go to atil tool, click dump bios, then go in to your ati tool directory and open the file 'bios' with wordpad and it will tell u
