Steam Steam Saves via Dropbox or similar?
Discussion in 'Gaming' started by sotu1, 11 Nov 2012.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Hi guys,
    Just had a brain wave and need you guys to vet the idea:
    Dropbox can act as a drive on your harddrive when it's actually on the cloud. Can you set your steam save files to be located there so you can play on another PC? Maybe, have it so that the local file on the 2 pc's are auto-copied and auto retrieved whenever they are changed?
    What's your thoughts?
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    I thought Steam Cloud enabled games took care of all that?
  3. Bogomip
    Bogomip ... Yo Momma
    15 Jun 2002
    Doesn't steam save games over cloud anyway?!
    Even if not you would need a pretty massive dropbox to do it as afaik there is no method of separating gamefiles and save games from their respective directories. You would almost certainly need to pay for it.
  4. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    How big are save files? I don't think all games have steam save files. Xcom for example has different save files for me different pcs
  5. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    \Steam\userdata is where most of the saves are stored. Your method can be achieved by using a NTFS symlink to a dropbox folder, but rather than fiddle with that I have a task scheduler job which copies my userdata folder to a backup location daily.
    I don't trust the Steam cloud much, they lose stuff sometimes >.<
  6. GeorgeStorm
    16 Dec 2008
    The number of times steam cloud says it can't save stuff etc means I wouldn't trust it if I wanted my saves in multiple places.
    Dropbox seems like a good idea
  7. Parge
    16 Jul 2010
    Could use Google Drive?
  8. GeorgeStorm
    16 Dec 2008
    Yeah that would work, it doesn't bother me since I only have the one pc.
    Steam cloud annoys me since it asks me what to do when it fails to update the cloud when playing something like tf2, where I think it is meant to be able to store configs etc, which could be useful.
    If I wanted to start backing stuff like that up, would you recommend drive over dropbox?
  9. wyx087
    15 Aug 2007
    dropbox are for noobs. :p
    use SVN, and commit the saves you are happy to the server. you can also branch your gameplay by creating SVN branches. before you go into a memorable mission, you tag that save point. also setup Trac to manage your gameplay progress, and perhaps even delegate tasks to your little brother. :D
    bigc90210 likes this.
  10. rollo
    rollo Modder
    16 May 2008
    Steam cloud keeps all your saves ive used my account on 2 pcs and transfered the saves no problem at all.
  11. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    ^^^ +rep. that is immense. extreme overkill, but immense all the same
    wyx087 likes this.
  12. adzc1987
    adzc1987 Minimodder
    19 May 2011
    I noticed in Civ 5 the steam cloud option, its a little annoying tbh having to pick to save there everytime.
    Mind you i dont really have a use for cloud savegames.
  13. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    :/ unless I'm missing something my Xcom saves don't cross PCs.
  14. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    Use simlinks to cloud save or look up gamestow or game save manager
  15. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    I've done it with this Link Shell Extension.
    Works perfectly. Install link shell extension and dropbox client. Move the folder with your saves to your drop box folder then right click and hold on the moved folder and drag back to the original location. you'll have a new option in your context menu which will be "drop as". Select drop as and choose junction. This will create a ntfs junction the same way steam mover does.
    I'm using this for steam and origin games and so far it's been great.
  16. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    Sounds good! So does this auto update the save files on both PC's o do you have to manually update it?
  17. scott_chegg
    16 Feb 2010
    You'd do that in the dropbox client. I created a folder on dropbox called Game Saves. I then set the dropbox client to sync that folder. I'm only using this on one PC at the moment so you'd have to configure the client on both PC's to do this.
  18. hughwi
    hughwi Minimodder
    23 Dec 2003
    nice, what happens if you dont have a little brother?
  19. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    +1. I LOL'd
  20. adzc1987
    adzc1987 Minimodder
    19 May 2011
    I think it depends on the game if it syncs, im certain none of my valve games (portal, HL2 etc etc) goto the cloud.
