Hardware Utopia Pandora Gaming PC Review
Discussion in 'Article Discussion' started by Dogbert666, 27 May 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    A novelty that would quickly wear thin as you maintain the daily cleaning routine.
    Having to do a weekly 'de dust' of my Corsair 450 case is bad enough, this would drive me to distraction TBH.
  3. DarkFear
    DarkFear What's a Dremel?
    14 Oct 2003
  4. jinq-sea
    15 Oct 2012
    That 980 looks awfully close to the back of the PSU!
  5. shindead
    shindead What's a Dremel?
    14 Aug 2014
    I didnt even notice it was there!!! I just glanced and assumed it was some form of metal plate :s
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    Apart from the obvious draw backs of an exposed PC (I would personally have a perspex over-case) I would have thought that for nigh on £2k they could at least use custom cables of the exact required lengths rather than use generic cables and cable ties... just seems lazy for that level of money.
    Those pointless red plastic (I assume) clip things on the frame also make it look awful, especially when wonky (1 upper rear) or missing (3 from top) as is the case in the first 2 images on page 1.
  7. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    It's like nobody here has ever seen a D-frame before?
    Also, why do people always bring up open cases as being dust traps? From my own experience they tend to be the opposite. If I compare the dust build up on Loramentum with my workstation in a normal case, Loramentum is just so much cleaner. Do you guys just live in really dusty environments or something?
    The only real drawback with open air style cases IMO is that your components aren't protected from things much, which is a consideration if you have young children or enthusiastic pets. Those are pretty legitimate reasons, but they also don't apply to everybody.
  8. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Ouch! That hurt my teeth!
  9. jinq-sea
    15 Oct 2012
    Yeah, but only watercooled ;) I hadn't twigged until this point that the GPU would be sucking on the PSU! I suppose the lack of an enclosure would help airflow, though.
  10. Dogbert666
    17 Jan 2010
    Oh wow, sorry! Fixed now. Thank goodness you're eyes were working...
  11. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    The positioning of the PSU vs the GPU is almost comical. It looks like it (The PSU) was added as an afterthought.
  12. HandMadeAndroid
    HandMadeAndroid That's handy.
    18 Feb 2005
    How did we get from beige boxes nobody gave a dam about to this?
  13. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    All that work, and then they go and ziptipe up the individually sleeved wiring. What a shame - this system could have really done with some cablecombs.
    (Well, and hard-line acrylic tubing, but that's suicidal in a mass manufactured rig)
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    :dremel::D
  15. Journeyer
    31 Aug 2006
    *Twitch*
  16. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
  17. HandMadeAndroid
    18 Feb 2005
    It's the equivalent of painting the microwave, or overclocking the washing machine
  18. Xir
    Xir Modder
    26 Apr 2006
    Yes, Kittens liked the heated, purring walk-in closets that big-towers with an open side door represented. :D
    Always wondered how they avoided getting pulled into the horrible fans we had back then.
Tags: Add Tags
