News Microsoft warns of Word zero-day vulnerability
Discussion in 'Article Discussion' started by Gareth Halfacree, 25 Mar 2014.
  1. Gareth Halfacree
    4 Dec 2007
  2. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    More people should try "Open Office" it will do what most people want for free and your not on the MS front line with all the scumbags trying to infect your software :wallbash:
  3. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    I just tried the fixit on my system, and it came back as does not apply to your system, I have win8.1pro +office professional plus 2013
  4. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    Unless you intend to send files to other Microsoft Office users.
  5. Gareth Halfacree
    4 Dec 2007
    OpenOffice (and LibreOffice) support loading and saving to both .DOC and the new DocX format, and the latest Microsoft Office fully supports the Open Document Format used by OpenOffice. I should know: I wrote an entire book in LibreOffice, sending the files in .DOC format to the publisher. Worked fine.
    Umbra likes this.
  6. Snips
    14 Sep 2010
    As I've said before Gareth, I've been sent files that have been unable to open within Office. It wasn't Microsoft's fault. I was even asked to download a copy of the software to be able to open the file. It never was and we never used the company again. The majority of the business world is using Microsoft Office, if you make an open version, at the very least get it to be compatible with the major player.
  7. RedFlames
    23 Apr 2009
    While interoperability between the two is a lot better than it was, there's still the odd issue on both sides... TBH I've had more grief with stuff done in iWork [Pages, Keynote and Numbers] than Libre/OpenOffice...
    That said, are RTF documents that common any more? Haven't come across/been sent one in ages...
  8. RichCreedy
    24 Apr 2009
    yeah I've had customers who have had issues with libre office and open office files when trying to use word/excel files.
  9. wolfticket
    19 Apr 2008
    Word is quite good though... Especially if you use the bits that most people don't use, and for a lot of people it's what they're comfortable with.
    Compatibility is a moot point as it works both ways, but I haven't found it to be perfect by any means working in either direction or indeed between different versions of MS Office..
    Most office packages will open files created in others but whether they'll look the same is another matter.
    This sounds like a fairly niche exploit since it relies on using Word to preview emails via Outlook. Not a huge issue for most users.
  10. theshadow2001
    3 May 2012
    Compatibility is ok not brilliant. I reckon most users Professional or otherwise would be fine with what Libre office offers. But they use ms office at work so they use it at home.
    Certainly I'll never buy office off of ms when Libre office us around.
  11. Umbra
    18 Nov 2013
    I'm sure it is and I'm not disputing that but I'm too tight to buy software that I don't use that much especially if a free open source program does what I want :D
  12. Alecto
    Alecto Minimodder
    20 Apr 2012
    Why would this be an issue? Microsoft Office is incompatible with different versions of itself so anybody locked into M$ Office ecosystem (either by foolish personal choice or by company decision) is already familiar with formatting getting lost when sending stuff around. Don't want your documents to get all messed up? Don't use M$ Office.
  13. Gareth Halfacree
    4 Dec 2007
    Why wasn't it Microsoft's fault? It certainly sounds like it was as much Microsoft's fault as OpenOffice's fault.
    Tell you what, let's get scientific here. You make a file in Word, save it as DocX, and send it to me. Then post a screenshot of Word displaying said file in this 'ere thread. I'll download the file, open it in LibreOffice, and post a screenshot of the same file - and we'll see how good the compatibility really is.
    You up for that, Snips?
  14. Snips
    14 Sep 2010
    How about you send me the file, since that's the major issue I've had with "open" Office.
    "The majority of the business world is using Microsoft Office, if you make an open version, at the very least get it to be compatible with the major player."
    I also said that but you cut it from the quote.
  15. Gareth Halfacree
    4 Dec 2007
    No need for the scare quotes, Snips; OpenOffice is open. Would you like a copy of the source code?
    Here's a file created in LibreOffice and saved as .DocX (although I can provide the ODT version, if you've got a copy of Office new enough to support the Open Document Format), and here's what it should look like:
    (Text courtesy Picksum Ipsum.)
  16. Snips
    14 Sep 2010
    Yep, that file works fine Gareth. Is that to Microsoft's credit then?
  17. Gareth Halfacree
    4 Dec 2007
    No, that's all on the LibreOffice devs; as far as Microsoft Office is concerned, that's a native DocX file. Now, if you want to paint Microsoft in a good light, try it again with the Open Document Format version. If Office loads that without corruption, then yes; that would be to Microsoft's credit. (It should, by the way; as far as I'm aware, ODT support in the latest Office is pretty solid.)
  18. Snips
    14 Sep 2010
    Yep, on this device it's only using Office 2007 and it works fine. So is that to Microsoft's credit?
  19. Gareth Halfacree
    4 Dec 2007
    Absolutely it is, yes. So, we're agreed: compatibility, at least for word processor documents, between LibreOffice and Microsoft Office is fine these days. Huzzah!
    Which means, of course, that this:
    has come to pass; the LibreOffice team did "get it to be compatible with the major player." Not bad for a freebie, hey?
  20. theshadow2001
    3 May 2012
    My only major complaint with Libre office writer is the image scaling tool is rubbish. If that was on par with Word it would be superdeeduperdy
