Hi All I want to get a real macro lens and have been looking at the canon 100mm non L there are Tamron 90mm Canon 60mm Canon 50mm which would you buy if you was getting one? any help appreciated thanks John
What do you intend on shooting with it? If it's insects then you'll need the working distance so go with the longer focal length.
Thanks i have ordered the canon 100mm now just waiting for it to be deliverd to currys store today there is a £45 off too from £373
