Motherboards ITX s1151 mobo with more than 4 SATA ports
Discussion in 'Hardware' started by phinix, 8 Mar 2016.
  1. phinix
    phinix RIP Waynio...
    28 Apr 2006
    Apart of Asroock, I only noticed that Gigabyte puts PCI express on their s1151 ITX mobos.
    Now, Can I use PCI Express port as 2 separate SATA3 ports?
    So if this Gigabyte Z170N Gaming 5 mobo has 2 PCI express ports and 2x SATA ports, does it mean I could actually use 6 SATA ports?
  2. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    The two SATA ports in the SATA Express port will working fine normally.
    From the listing - "2 x SATA Express (Compatible with 2x SATA 6.0 Gbps)"
  3. phinix
    28 Apr 2006
    Yeah, so do they mean 2x SATA express will work as 2x SATA 6.0?
    Or, should that say - 2x SATA Express will work as 4xSATA 6.0?
  4. meandmymouth
    15 Sep 2009
    Each SATA express should work as 2 normal SATA ports, so 4 total.
    EDIT: 6 total on the board, that is.
  5. RedFlames
    23 Apr 2009
    as meandmymouth said, you'll have 6 usable SATA III ports, plus the m2 slot on the underside of the board...
  6. phinix
    28 Apr 2006
    Cool, I was looking for a mitx mobo with more than 4 sata.
    I wonder why they put that pci express sata when its a dead end anyway...
  7. Guest-16
    Guest-16 Guest
    Tick box. Everyone does it. It'll disappear by next gen.
  8. phinix
    28 Apr 2006
    Yep. At least it gives us 2 extra sata.
    Itx format is fine with 4 sata sockets but sometimes its good to have small mobo in data center pc.
  9. Guest-16
    Guest-16 Guest
    Agree, I have both H77 and H81 ITX with 6 SATA at home :) H81 is in my NAS with all used (and a waayyyyyy overpowered 4790 ¯\_(ツ)_/¯)
