Windows What is the best Hard Disk defrag software?
Discussion in 'Software' started by taffinator, 9 Feb 2012.
  1. taffinator
    taffinator What's a Dremel?
    6 Feb 2012
    Hi all, just noticed that accessing my files seem to be getting slower over time. There doesn't seem to be a way to do it on windows so some genuine 3rd party software would do, cheers.
  2. Jor1995dan
    Jor1995dan Minimodder
    6 Feb 2011
    If you're excusively looking for third party software, I like O&O Defrag Professional: it's not cheap, but is well worth the money.
    Windows does have a built in tool, if you want to use it, then go to go to My Computer/Computer depending on your OS, then right click on the drive and go to Properties. Click on the Tools tab then press Defragment Now. Then voila! Your drive is defragmenting :) If you need any more assisstance, then don't be afraid to ask.
  3. Deders
    Deders Modder
    14 Nov 2010
    Perfect disk is a good one too, the only one I've found that organises files based on how much they are used Like Norton Utils used to.
  4. Paradigm Shifter
    10 May 2006
    I've not been impressed with paid-for defrag software since Vista arrived on the scene. All of them make grand claims about how they defrag the MFT... which they do, if you're using XP. O&O, PerfectDisk, DisKeeper... tried various ones and they always report that they've defragged the MFT in Vista/7 (boot-time defrag tried as well) but analyse the drive again, and *bang*... MFT still in n fragments.
    Spent days detailing everything to O&O once, who, to their credit, were very helpful - sending me beta builds to try and all sorts.
    Long story short, I've given up on defrag software that costs me money, and use Defraggler, by the same people who make CCleaner and Recuva.
  5. Daedelus
    Daedelus What's a Dremel?
    7 May 2009
    If you have SSD you shouldn't use defrag.
  6. Deders
    Deders Modder
    14 Nov 2010
    I think Vista/7 re-arrange the files on boot. Just defragged and checked again an hour later, only 13 files are now fragmented (from 0) I think this can be attributed to background processes and cookies for the web pages I've accessed since.
  7. Steelez
    Steelez Minimodder
    16 Jan 2004
    Defraggler is good, as mentioned by Paradigm Shifter but since I switched to Windows 7 I've just been using the built in tool.
  8. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    I only use O&O defragger
    sent from HTC Sensation
    JBond likes this.
  9. Cleggmeister
    Cleggmeister Of reasonable knowledge...
    12 Oct 2009
    O&o by a country mile.
  10. JMMD
    JMMD What's a Dremel?
    4 Feb 2012
    Defraggler but now I'm going to check out this O&O software.
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Defraggler is what I use
  12. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Auslogics anyone?
    Has the features of the paid version of defraggler for free!
  13. digitaldunc
    digitaldunc What's a Dremel?
    4 Oct 2010
    Surprised nobody mentioned Mydefrag -- it has different scripts based on the type of defragmentation you want to perform (Weekly, monthly, daily etc)
    I've used it on clients machines for a while now, does what it says on the tin.
  14. kenco_uk
    28 Nov 2003
    I thought Defraggler superceded MyDefrag?
    I use Defraggler too. If I'm doing a good clearout, I'll use CCleaner, then use MS Disk Cleanup, then disable and delete the pagefile and hibernate file. Then run defraggler. Then reactivate the pagefile and hibernation file if required.
    Just wondering, is there a free tool that'd defrag the pagefile and hibernation file?
  15. Gareth Halfacree
    4 Dec 2007
    Defraggler certainly used to, back when I was still using Windows. T'was an option - can't remember if it was just a toggle or if it ran a separate defrag run specifically for those two, tho'.
  16. bulldogjeff
    2 Mar 2010
    Defraggler and the built in windows option both work just fine for me.
    JBond likes this.
  17. Dwarfer
    Dwarfer What's a Dremel?
    30 Mar 2011
    MyDefrag & Defraggler
    JBond likes this.
  18. asura
    asura jack of all trades
    22 Apr 2009
    +1 for mydefrag
  19. digitaldunc
    4 Oct 2010
    Pagedefrag will do this -- part of the sysinternals suite, which is well worth checking out.
    thehippoz likes this.
  20. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    My system is setup to defrag drives at 1pm every Wednesday. Although I think it really does it when the system is idle, as I've never noticed it doing it.
    And my drives are all according to windows, 0% fragmented, or as near as.
    This is on 3 drives, just under 2TB worth.
