Windows Space on C: mismatch
Discussion in 'Tech Support' started by Pookeyhead, 3 Aug 2014.
  1. Pookeyhead
    30 Jan 2004
    Just noticed something...
    On C: WinDirStat shows used space as 21GB
    but windows reports 43GB being used...
    I've disabled hibernate using powercfg -h off. I have no system restore set, and that is disabled.
    Where's the extra 22GB??
  2. aramil
    aramil One does not simply upgrade Forums
    10 Jul 2012
    Windirstat is misreporting by the looks of it.
    Says you have 0mb of "user" files & settings. Which even on a fresh install should be something.
  3. faugusztin
    11 Aug 2008
  4. Pookeyhead
    30 Jan 2004
    No that's right. Users is 1.7GB and documents and settings is not located on C: in my system.
    Thanks for the link faugusztin. I'll check through that later. Still installing stuff. Yes it's a new install.
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Is diskmanagement showing the same used space as the properties of the C: drive ?
  6. Pookeyhead
    30 Jan 2004
    Yes it is
  7. Pookeyhead
    30 Jan 2004
  8. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    sounds like a permission issue where windirstat doesn't have permission in its run context to see or access all files & Directorys.
    /ninja'd Corky, but his gives more detail :)
  9. Corky42
    30 Oct 2012
    Just some random stuff that springs to mind, AFAIK WinDirStat wont be including the pagefile.sys in its size calculations, or any files in the "System Volume Information" folder, you could grant access to it just to see if there is anything hidden in it.
    Also when you disabled hibernate, did it remove the hiberfil.sys
    I guess chkdsk reports there's no problems.
    Other than that it could be something to do with permissions as WinDirStat won't list files it doesn't have access to, like Volume Shadow Copy, System Restore, System Protection.
    I guess you run WinDirStat as admin.
    deathtaker27 likes this.
  10. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    Does similar here. I believe it is due to the way Windows reports junctions as it can't tell the difference between a junction and an actual file. That makes the used space reported to be much higher than it really is.
  11. Pookeyhead
    30 Jan 2004
    Oh well.. Damned if I can sort this out... Lol
  12. ferret141
    ferret141 Minimodder
    18 Oct 2010
    I know it's not a solution but try SpaceSniffer just to see if it reports different.
