Case Mod - In Progress [Project] my DixPlay (4th Update - 05.10.15)
Discussion in 'Project Logs' started by thegyufi, 22 Sep 2015.
  1. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    Hi Bit-Tech ! :dremel:
    After my last two projects based on an Apple Cube and the PowerMac G5, I'm back for a new project !
    As you probably already guessed I keep an Apple base, and this time it will be an iMac 24" !
    This time, the challenge is even bigger, I will be the first one to do something like this !!
    So some help will not be too much !!
    Let's the party begin ! :dremel:
  2. thegyufi
    21 Mar 2011
    todo list !
    - work
    needtofind list !
    - iMac 24" glass
    - IEC a1225
    - 24" Led monitor 16/10 (1980x1200)
  3. thegyufi
    21 Mar 2011
    reserved 2
  4. thegyufi
    21 Mar 2011
    [1st Update] 22.09.15
    So this is the case like it is today :
    the first area where I will start
    the hardware will have 4 USB 3.0, so the firewire must leave !
    the display port must be refill
    after a quick sanding
    a little spray primer shot
    then this is how I integrate the HDMI plug
    That's it, I'm still waiting to receive the others wires to continue.
    Stay tune ! :rock:
  5. bigc90210
    bigc90210 Teh C
    7 Oct 2003
    liking the look of this! Good luck! - Subbed
  6. arduum
    arduum Minimodder
    10 Mar 2015
    O My GoD!
    It's amazing! Subbed!!!
  7. IceTouch
    IceTouch What's a Dremel?
    26 Aug 2015
    Woah!! Nicely done! What did you use to fill the port?
  8. thegyufi
    21 Mar 2011
  9. IceTouch
    26 Aug 2015
    Thanks for info, can't wait to see more! :D
  10. thegyufi
    21 Mar 2011
    3rd Update ! 24.09.15
    here is the result !!
    I still need to wait for the USB 3.0 extensions !! :grr:
    :dremel:
  11. thegyufi
    21 Mar 2011
    After almost 3 weeks, I finally received my USB 3.0 extensions !! :D
    No time to waste ! Mount !
    Thats it, the I/O part is now finished :clap: Now I have to find a 24" screen (16/10) to continue the project !
    Stay tune !
  12. arduum
    arduum Minimodder
    10 Mar 2015
    HEY, where're you?
  13. thegyufi
    21 Mar 2011
    hey ! Finally, after few attemps I received this monday, an unbroken glass !! So the project can restart, I just ordered a used display (HP ZR2440W) I hope it will fit inside :D
  14. arduum
    arduum Minimodder
    10 Mar 2015
