Hey all, Does anyone know where I might be able to get a backplate for my EVGA GTX 760 SC ACX ? I don’t mind what make etc. I know that EVGA make one, but I cant find it stocked in the UK. Ive tried my usual haunts such as specialtech, overclockers, scan, even amazon! Any ideas?
Shirty....... your a star. Thats just what im after. It doesn't list compatibility, but il check thr dimensions when im home hopefully should be fine. Thank you!!! Sent from my GT-I9505 using Tapatalk
Assuming the PCB is compatible (the matching block is listed as being compatible with "EVGA GeForce GTX 760 Superclocked ACX Cooler 2GB GDDR5 (02G-P4-2765)", just be aware that you might need to get creative with the mounting, as I suspect the NexXxoS uses bolts designed to go into the matching waterblock. Maybe an excuse to wc the whole thing eh?
