Build Advice Need Help With A Gaming PC Build
Discussion in 'Hardware' started by oliverr97, 31 Jul 2011.
  1. oliverr97
    oliverr97 What's a Dremel?
    31 Jul 2011
    I am looking into buying a new Pc for around the £650 price mark, mainly for Gaming and other general use. I probably will be doing some overclocking on it and i don't need any peripherals, or a monitor or OS. I will be playing at 1920 x1080. Here is my list so far, is this build ok?
    Intel i5-2500k
    Corsair Vengeance 4gb (2x2gb)
    Samsung Spinpoint F3 1tb
    Msi Gtx 560 Ti Twin Frozr II/OC 1gb
    Coolermaster Haf 912 Plus
    MSI P67A-GD53
    Corsair Cx430
    Coolermaster Hyper 212 Plus
    Thanks :D
  2. westham101
    westham101 MWN Gamer
    13 Jul 2010
    Looks fine to me mate, Get 1600MHz ram.
    You will definately need a higher wattage Powersupply!!!!
    I would suggest a 650watt powersupply.
    Corsair HX 650watt - £97 -85% (Modular)
    Enermax Modu87+ 700watt - £145 - 91% (Modular)
  3. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    He doesn't *need* a higher wattage PSU it would just be beneficial for future upgrades. The two you have listed are also far too expensive considering the total build cost.
    For £650 I would build the following:
    Case - BitFenix Shinobi - £50
    PSU - BeQuiet L7 530w - £44 (I run this myself - PC in sig)
    MB - MSI P67A-GD53/55 - £115
    CPU - i5 2500k Retail - £160
    Memory - 4GB (2x2) PC12800 DDR3 - £30
    GPU - GTXHD6870 - £140
    HD (boot) - Crucial M4 64GB - £90
    HD (Storage) - Spinpoint F3 1TB - £45
    Total: £674
    Slightly over budget but you get the major advantage of a SSD acting a boot / primary gaming drive (enough for a couple of games).
    The i5 2500k / HD6870 combo will be enough for the majority of games at 1080p w/ high settings. A GTX560 or even the 560Ti would be alternatives although you would probably have to sacrifice the SSD in order get the latter.
    Personally, I would lose a bit of GPU grunt to gain the advantages of the SSD although that choice is entirely down to personal preference and whether you are willing to sacrifice one thing to gain something else.
  4. Parge
    16 Jul 2010
    Agree with this. Also agree the BeQuiet 530w would be a great choice.
  5. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Due to it being a gaming pc you would better off with a 560ti than a 6870 & ssd. Also the arctic freezer 7 is a better CPU cooler.
  6. Parge
    16 Jul 2010
    All the same, I'd definitely be looking to stick an SSD there if possible, even if its just a 40GB one for your Win7 install.
  7. Kemp
    Kemp Minimodder
    22 Jul 2011
    There's a name I haven't heard in a while. :hehe:
  8. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
    He could not bother with a cpu cooler and buy a better gpu for the moment if he's not planning on overclocking just yet and buy the cooler at a later date when he's ready.
  9. xaser04
    27 Jun 2008
    At this budget a CPU cooler can wait, Core components take priority; especially as SB runs relatively cool even on the stock cooler.
    Changing to the GTX560TI is a valid point (hence why I made a caveat in my post above) although personally I wouldn't want to sacrifice a SSD to gain an extra few FPS.
    An ideal scenario for the Op would be to get a good balanced system now with a GPU that can cope with 1080p gaming (so a HD6850-HD6870 / GTX460-GTX560), and then upgrade to the next gen cards proper later on this year.
    Anyway to summarise:
    If the op wants balls out gaming performance then sacrifice the SSD and get a faster GPU. If he wants a more all round pc that will also east up the games get a slightly slower GPU and use the balance of the budget to get a decent SSD.
    Drop in a aftermarket cpu cooler in 1-2 months when the build has "bedded in".
  10. Sponge12349
    Sponge12349 (づ。◕‿‿◕。)づ ︵ ┻━┻
    12 Apr 2010
    What about this lot for £378?
    http://www.scan.co.uk/todayonly/
    Coolermaster CM 690 II Advanced Dominator
    650W Antec TruePower
    Intel Core i5 2500K
    1TB Western Digital Caviar Green
    8GB (2x4GB) Corsair DDR3 XMS3
    Pioneer DVD+RW
  11. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Add in a GPU and SSD and you'll still be a decent bit under the £650 budget
  12. stefan442
    stefan442 Minimodder
    14 Mar 2011
    plus a 2gb 6950 for 200 notes and a ssd = win
    just noticed.... no mobo!! :duh:
  13. meandmymouth
    15 Sep 2009
    I failed at that too... oops
  14. Chebob
    Chebob What's a Dremel?
    5 Jul 2011
    Im looking to build a gaming pc atm aswell, Im building it around a i5 2500k (£140) 2gb 6950 (£200, 2GB so it can be flashed to a 6970) and maybe an ssd, so its pretty similar to what others are suggesting, if you want you could drop the ssd and get a 6990, but it would still end up costing maybe £100 more overall but its worth considering.
    Edit before ive posted: Look at my excellent budgeting skills :/
  15. westham101
    13 Jul 2010
    Didnt see his budget sorry.
    Also he actually does need a higher wattage powersupply! A 430 watt powersupply shouldnt be the choice for a i5 2500k and a gtx 560TI overclocked twin frozer II edition.
    http://educations.newegg.com/tool/psucalc/index.html
    Enter all of his specs and you'll find it will come to about 480watts.
    He might be able to get away with 430watts, but I would definately recommend a better powersupply.
