PSU New Seasonic PSU REALLY CRAP CABLES!
Discussion in 'Hardware' started by ShinyAli, 24 Nov 2012.
  1. ShinyAli
    ShinyAli What's a Dremel?
    14 Sep 2012
    I recently bought a Seasonic 550W gold standard PSU after getting some good recommendations on another thread I posted here :thumb: and the PSU has just arrived and while the PSU looks good I have not yet tried it as my sig build is not quite ready for it, but, the biggest disappointment are the modular cables, "THEY ARE THE NASTIEST, CHEAPEST LOOKING CRAPPIEST CABLES I HAVE EVER SEEN" OK, rant over, but they really are, they are not even braided badly there is no braiding at all and they are not even colour coded :miffed: :confused:
    The cables are the horrible flat type and as soon as you start bending them around you can see that the wires are going to start separating and will quickly turn into a tangled mess, this is not what I expected for an £80 gold standard PSU, even my old Zalman modular PSU has all the cables braided and they are quite well done.
    When I opened the box I thought "Oh great, another really useful pouch" but actually it will be useful as I can hide the unused modular cables in it :rolleyes:
    I will be braiding the cables but that's not the point, to me these are horrible, nasty cables of the lowest quality and the sort of thing you see hardwired on really cheap PSU's, NOT IMPRESSED, NOT AT ALL :miffed:
    Not surprising that there are no pictures of the cables on the Overclockers advert.
    Think I will have to leave a suitable review on Overclockers site :eyebrow:
  2. sniperdude
    sniperdude Minimodder
    8 Sep 2010
    same as corsair cables from what i recall
  3. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    It's the cheapest 550W Gold PSU on the market, and Seasonic aren't known for their value so they cut corners in their G series. You should be happy you have such a solid spec performer for £80.
    Be Quiet, Thermeltake, Silverstone, etc models are all at £100. The Seasonic X-560 is £130. You get what you pay for tbh :)
  4. ShinyAli
    14 Sep 2012
    Really, Well I don't pay £80 for cut corners and fu**ing crap cables :miffed:
  5. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I hate flat cables, sata cables are awkward to route neatly so why psu companies choose to use flat cables is beyond me.
  6. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Aside from a (subjective) aesthetic point of view, I don't see what the problem is with these cables. I have similar cables on my modular Corsair PSU and haven't found anything to bother me.
  7. Teelzebub
    27 Nov 2009
    If you don't like it spend more and get what you do like, Seems simple enough to me.
  8. mrbungle
    20 Sep 2004
    £80 for a 550w psu
    Screw that.
  9. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    No, you paid £80 for high efficiency, quality power and silent operation upto high loads.
    I can understand your disappointment, but you just need to get used to the market! £80 isn't a lot for a good 550W PSU any more.
  10. ShinyAli
    14 Sep 2012
    And how are you supposed to do that when no pictures of the cables are shown in the advert, I spent £65 on a Zalman gold standard PSU 3-4 years ago and all the cables a were well braided with heatshrink there were no corners cut with that PSU, you got the quality alround.
    So seasonic sell a gold rated PSU but if you want decent cables you have to pay even more, that attitude stinks to me.
  11. PabloFunky
    PabloFunky What's a Dremel?
    19 Sep 2010
    I bet the cable they use is the same as cable under braid.
    Braided cable is just bling, doesent make it quality.
    It may help if played about with alot, but why would you do that anyway.
    I bet that cable they used would be as high if not higher than any competitions.
    If its in spec then thats all you need.
    Also to be fair heatshrunk cable is only 1 step up from electrical tape. Over moulded cables are always best, which you dont see that often though.
  12. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Give this back and buy yourself a Zalman. The main thing is to be satisfied, if you don't value what this PSU offers then you're wasting your time.
    Edit: and I know I specifically said "cut corners" but I didn't mean it literally, Seasonic hasn't cut corners they've just used standard cables.
  13. ShinyAli
    14 Sep 2012
    I intend to ;)
  14. ShinyAli
    14 Sep 2012
    Cause this is a modding forum and for some sleeving and braiding is considered modding.
  15. azrael-
    azrael- I'm special...
    18 May 2008
    They're the same kind of cables that came with my Corsair HX520W (incidentally made by Seasonic). I find these cables to be excellent and I actually wish the Seasonic X-560 came with similar cables instead of the oldfashioned braided ones. I've also never had issues routing this specific type of cable.
  16. sniperdude
    8 Sep 2010
    Braided or not I do my best to hide power supply cables and the flat ones are more easy to hide TBH
    Only cables that look nice are individually braided cables the rest should be hidden IMHO
    honestly your PSU has way more pros than cons
  17. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Agreed
  18. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    ^ This. Cabling is a pain in the arse. My Pro AX-750W (pretty much the highest-spec-line Corsair make) comes with exactly the same sort of cables. The lack of braid and sleeve makes these approximately a million times easier to route and I'm very happy with them.
    Then, er, mod them? :confused:
  19. sniperdude
    8 Sep 2010
    personally I think modding PSU cables is a bit of a nightmare I would never even try it.
    Voids warranty
    takes ages
    costs a packet
    I just bought braided extensions for my main cables 24-pin, 8pin and 2 PCIE cables
  20. MrTeal
    MrTeal Minimodder
    27 Aug 2010
    There are reviews for the G-550 (and others in the series), you could have read them to get more of an insight into the product.
    Don't know what a gold standard PSU is. If you're talking about 80 Plus Gold then AFAIK Zalman have only recently (in 2012) released their first 80 Plus Gold PSUs in the GoldRock ZM-XG series.
