[Build-LoG] Ice Blue
Discussion in 'Modding' started by Ficu, 14 Apr 2012.
  1. Ficu
    Ficu What's a Dremel?
    8 Sep 2011
    Thank you very much to all members and sponsors who have and are helping in this project.
    -Hardware:
    Motherboard: Gigabyte Z68X-UD7
    Processor: 2500k
    RAM: Corsair Vengance LP
    GPU: Evga GTX480
    PSU: Antec HCP-850
    SSD: OCZ Agility 3 60GB
    Case: NZXT Switch 810 White
    -Liquid-cooled:
    Block CPU: Ek Supreme HF Plex-Nickel + Mounting Plate Nickel
    Block GPU: Aquacomputer GTX480 Nickel.
    Block Motherboard: Ek Nickel - Plex UD7
    Back plate: personalized By Cold-Zero / Aquacomputer Single Slot
    Radiator 1: Ek XTX 360
    Radiator 2: Ek XTX 240
    Radiator 3: Ek XT 120
    Radiator ventilation: x6 DeepCool UF120
    Case ventilation: Gelid 140mm
    Pump 1: Laing DDC 1T Plus 18W
    Pump 2: Laing DDC 1T Plus 18W
    Reservoir 1: Ek Res X2 250mm Advanced
    Top: Ek DDC Dual Top Aquacomputer
    Fitting: Alphacool HF Nickel 16/10mm
    Angled Fittings: Angled 45º, 90º Alphacool Nickel
    Adapters: Alphacool HF G1/4 @ G1/4 Nickel
    Extenders: Phobya G1/4 rotary Nickel
    Plugs: Phobya Nickel
    O-Ring: Phobya Blue UV
    Grills: personalized By Cold-Zero
    Tube: Masterkleer 16/10mm
    Liquid: Mahyems Blue Berry
    -Other:
    Display: Phobya Thermosensor Azul
    Adapter Display: XSPC 5.25" Temperature Sensor Frame
    Sata Cable: x2 Mod/Smart White 60cm
    Sleeve Kit Mod/Smart Basic White
    Silent Blocks: Noise Blocker Blue
    Thermal paste: Artic MX-4
    Cables: Full Sleeve White / Blue
    Adapter: Phobya 3 pin @ x6 3pin White.
    Extension: Molex 4 pin Mod/Smart 40cm White.
    -Photo of the week
    -Current
  2. Ficu
    8 Sep 2011
  3. Shazbom
    Shazbom What's a Dremel?
    18 Jan 2009
    Nice sleeved extension. modpcuk from ebay right?
  4. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Nice start man !
    Good photography too !
    Subbed !
  5. Ficu
    8 Sep 2011
    Yes :)
    Thanx!
    Well, here the expected photos!
    First of all, Many thanks to Frank for having gotten this Canarinfo I5 3570K CPU as part of sponsorship in this project.
    I have to give thanks to Noah greatly Gigabyte Spain for having engaged in this way in our project, THANK YOU!
    A photo of the "marriage" :)
    And the bag from Gigabyte .. That cool .. no? :)
    Saludos!​
  6. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Nice package ! Congratz !
  7. rak500
    rak500 Minimodder
    22 Aug 2009
    Promisiing start! Can't wait to see it all built up!
  8. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    well when someone asks me 'bout geek pr0n i'll give him link to this thread... MOAR PIX!!!
  9. Ficu
    8 Sep 2011
    Thanx
    :thumb:
  10. Reconnec7ed
    Reconnec7ed What's a Dremel?
    29 Feb 2012
    Very nice project!
    But are you sure your supposed to be posting about the 3570K? Could get your man in some trouble?
  11. Ficu
    8 Sep 2011
    Y........ WC Pr0n!! :) Gracias a:
    EK Supreme HF Plexi-Nickel + Mounting Plate Nickel..
    EK Supreme HF Plexi-Nickel + Mounting Plate Nickel + Alphacool HF 16/13...
    EK Supreme HF Plexi-Nickel + Mounting Plate Nickel + Alphacool HF 16/13 + Blue Berry..... Oufff!
    O-ring Phobya.
    I like Nickel?
    Display Phobya ( x2 ) and XSPC adapter
    Top doble DDC Aquacomputer
    Silent-blocks Noise Bloker Blue y unos Leds Blancos de 3mm para el HF
    Gelid 140mm
    Phobya Flexi-Light 240cm White
    Saludos!
  12. Ficu
    8 Sep 2011
    Here we are back to show Coldzero material created by this project. Thank you Richard!
    Bonus pic´s: Alphacool HF 16/13 + 0-ring Phobya Blue!
    Un saludo.
  13. Nexxo
    23 Oct 2001
    Project Log rule no. 2...
    Moved to Modding.
  14. echo three
    echo three What's a Dremel?
    26 Jan 2012
    There's some shiney parts there,
  15. Ficu
    8 Sep 2011
    Thanx..
    HF Mounting plate Nickel + M4 Inox :)
  16. Ficu
    8 Sep 2011
    Of Canarinfo:
    Radiator Ek XT120, EK FB Kit P67/Z68-UD7 y x2 Laing DDC 1T Plus
    Of Antec:
    Thanx Josep of Antec España!
    Review:
    Review: Antec High Current PRO 850
    Of Corsair:
    Thanx Gareth!
  17. Vetalar
    21 Jun 2011
    how are those deepcool fans? i've read some negative feedback for PWM version...
  18. Ficu
    8 Sep 2011
    They are the best in performance the truth, but are very nice..
    Well, the radiators are painted ... I have put various configurations of fans to compare, to see what do you think ...
    DeepCool UF120
    Corsair SP120 White ring
    Corsair SP120 Blue ring
    Ek XT120 + Corsair SP120 + Alphacool HF 16/10
    Ek XTX 240 Instalado
    Ek XTX Installed
    XTX360 + Grill ColdZero
    Thanx.
  19. Ficu
    8 Sep 2011
    80% finish the issue of lighting!
    Thanx!
  20. Vetalar
    21 Jun 2011
    man You've got wrong EK logo - no circles over... everywhere :)
