Hardware Fractal Design launches Define Mini case
Discussion in 'Article Discussion' started by arcticstoat, 31 Dec 2010.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. FelixTech
    FelixTech Robot
    12 Jun 2009
    How does this compare size wise with that 'Beast' PC Custom PC made?
  3. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Fractal Define Mini: 210 x 395 x 490mm (WxHxD)
    Beast (Antec P180 Mini): 283 x 510 x 515 mm (WxHxD)
    So smaller than the Beast all round.
    The Define Mini looks great, can't wait for a review.
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    Nice looking case. Can't wait to see some numbers!
  5. maximus09
    maximus09 Forever n00b
    8 Jun 2009
    SOLD! Will by this as soon as it comes out, thanks Fractal!
  6. docodine
    docodine killed a guy once
    10 Feb 2007
    Looks like an improvement over the Mini P180 in every way.. It's a shame that the only way for me to get one is to order from Canada (Is NCIX still the only place selling Fractal Design products to Americans?)
  7. HyBry
    HyBry What's a Dremel?
    13 Feb 2008
    I am not fully sold that a full length GPU can fit there comfortably even after removing the top HDD cage.
    But I am sure they have thought of that. Looking at it for a potential next upgrade.. :)
  8. hbeevers
    hbeevers Yes, it can play crysis!
    24 May 2010
    they know that cooling is an issue with small cases so they put in 6 fan mounts but i don't see any dust filters? If it's a bottom mounted PSU with no dust filter then they're mad.
  9. Fingers66
    30 Apr 2010
    "Supports graphic cards with lengths up to ca 260mm when removable HDD-bay is in place"
    "Supports graphic cards with lengths up to ca 400mm when HDD-bay is removed "
    "No PSU included (removable filter below PSU)M/B compatibility: Mini ITX and Micro ATX "
    Source: http://www.fractal-design.com/?view=product&category=2&prod=58
  10. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
  11. nemo
    nemo Foregone Destruction
    16 Jun 2010
    Nice, but the first photo of the article should have included a coke can or something to give a sense of scale
  12. Jipa
    5 Feb 2004
    No it isn't.
    There are filters.
  13. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Looks like my current F.D. "array" case is on it's way... mine has/ is having problems with the 12v line dropping to 8 V, so a bit more room for an ATX PSU is a good thing IMHO.
    dunx
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    For a µATX this case is way too big compared to an Antec Threehundred with 205 x 457 x 465 mm or even better a LianLi PC-A05 with 210 x 381 x 490 mm, which are both fullATX-towers.
    A Sugo SG30 is what I call a real µATX-case with 200 x 360 x 312 mm. Space for 2x 3.5"HDD + 1x 5.1/4" optical and you can even fit GPUs of up to 10.5". A H50 or H70 for cooling the CPU and voila you've even rexolved the issue of the PSU-positioning not allowing for big coolers.
    I'm not impressed at all tbh and would rather buy a normal sized Define R3 instead.
  15. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Was looking at buying Mini P180 but I'll be buying this case instead. Looks a lot nicer and having the power button on top rather than behind the door seals the deal.
  16. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Aside from the array R2, ive got to say im not a fan of any of fractals cases. Its nice to see a unified look to the whole range, but id like to see something new tbh, not just smaller/bigger versions of the same case.
  17. subtec
    subtec drawing boxes
    4 Nov 2010
    40 liters is small? If you say so...
  18. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    As above... Pretty much bigger than most uATX cases...
  19. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    +1 but i'm sure BT will be doing a full review ASAP.
    Now just need to find a company that does nice wooden boxes for transport of full rig.
  20. das_mod
    das_mod What's a Dremel?
    13 Jul 2005
    I hope the other side panel is removable with easy access to the CPU area...
    Im sick and tired of cases that force me to remove the whole motherboard to install a bracket for cpu cooler upgrades.
Tags: Add Tags
