Scratch Build – In Progress Project: TRON
Discussion in 'Project Logs' started by timerhan, 6 Nov 2012.
  1. timerhan
    timerhan What's a Dremel?
    6 Nov 2012
    Hi all!
    I wanted to share with you my project. The project is based on the movie Tron: Legacy. The main idea of ​​the project was taken at L3p D3sk, for which he thanks a lot :thumb:
    Really needed a computer desk, this decided to do it with the integrated system.
    I apologize for my English, I use "Translate Google" )))
    My system:
    i7-920 + EK-Supreme HF
    Gigabyte X58A UD3R + EK-NB/SB 6
    Asus GTX580 DCII + EK-VGA Supreme HF
    ASUS Xonar D1
    1Tb WD Caviar Black + 500Gb WD Caviar Blue
    Corsair 650HXEU
    Swiftech MCP355 + EK-DDC X-RES 140 VERSION 2
    XSPC RX480 Extreme Performance Radiator
    To start drawing drawn:
    So what did the layout, scale 1:10:
    Dismantled the rear wall and frame mount, his old body Termaltake V9.
    Installing the motherboard tray:
    It will look like in the collection system:
    Painted mounting video and sound card:
    To cool the VRM I used passive radiators Enzotech RAM (BMR-C1):
    They had to be cut down a bit and paint:
    Radiators come perfectly! :D
    Radiator XSPC RX480 installation:
  2. dream1
    dream1 What's a Dremel?
    26 Feb 2011
    Nice start i like the vrm coooling :)
  3. timerhan
    6 Nov 2012
    Thank you! This is my first project ... I hope everyone will like it))))
  4. timerhan
    6 Nov 2012
    Complete system:
    Install the power supply. The power supply is outside. For it made ​​a fan out:
    Been thinking about the design of the front panel. As a result, I decided to paste over DVD-ROM plastic plate:
  5. timerhan
    6 Nov 2012
    Installed on the side panel are two fans:
    Used Thermalright X-Silent 120 and filter:
    Water block for fastening painted in black:
    I bought a neon cord, UV acrylic and UV lamp:
    Glass installed around the motherboard:
    Just set the band for memory:
    It was evening:
  6. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    I'll just ask since I can, but your image hosting seems to be blocked from my location, you wouldnt consider swapping to like photobucket, I would love to see some TRON modding xD
  7. Owndapwn
    Owndapwn What's a Dremel?
    13 Jul 2012
    ._.
    Pretty lights.....
    What is this "neon cord" you're using, how does it work, and where can I find some?
  8. Yaka
    Yaka Multimodder
    26 Jun 2005
    The geek in me loves all things related to tron, just a damn shame tapatalk Keeps crashing, can't wait to get home and get a proper look at the pic
  9. timerhan
    6 Nov 2012
    Balder, a link to the hosting without registration, pls )))
    Owndapwn, "neon cord" - http://www.pcdesign.ru/faq-neon_worm.shtml (description "neon cord" in Russian) )))
    Yaka, big picture? And I do not understand)))
  10. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    That ^
    And I love the VRam cooling, looks very good :)
  11. timerhan
    6 Nov 2012
    Thank you))) I also like very much : Dremel :
  12. timerhan
    6 Nov 2012
    A little update. Installed on HDD UV Acrylic:
    After work, accidentally stepped on the tool and broke it (((
    HDD in the night)))
  13. Grizlebeez
    Grizlebeez What's a Dremel?
    6 Sep 2012
    this is super wierd.....im doing a Tron themed build right now as well. nice work man!
  14. Cheapskate
    13 May 2007
    Looks good.:D Will you use 'false floor' panels to hide the cables?
    The material on the optical gave me an idea. If I covered my desk with grip tape, I could sand stuff at the computer.
    ...Using the mouse might get bloody that way, though.:worried:
  15. timerhan
    6 Nov 2012
    Thank you))
    Already bought a sheet of perforated metal, and made to do the pallet ...
    Later will be pictures)))
  16. timerhan
    6 Nov 2012
    Today made pan ... Some photos)))
    Tomorrow I'll paint)))
  17. l3p
    l3p www.^.nl
    1 Nov 2010
    Really love what you did with the neon lights, can't wait for more!
  18. timerhan
    6 Nov 2012
    Thank you! :)
    UV light is very impressive looks, try to make the band in the movie Tron)))) :dremel:
  19. timerhan
    6 Nov 2012
    Finished with a tray ... A hole for the HDD and the pump:
    More recently bought a Crucial M4 128Gb and made a basket for SSD and HDD:
  20. timerhan
    6 Nov 2012
    Found in a toy store))))
    Later used in the design of the model))))
