Storage Enterprise HDD comparison WDD 1TB RE4 vs Seagate ES 1TB
Discussion in 'Hardware' started by Dark Matter, 30 Mar 2013.
  1. Dark Matter
    Dark Matter Minimodder
    12 Mar 2010
    Hello,
    About to install WS 2012 on my home server and have both of these drives. The server will be on 24/7
    Seagate ES 1TB SATA HDD (ST1000NM0011)
    Seagate
    Vs
    Western Digital RE4 1 TB SATA HDD ( WD1003FBYX)
    Western Digital
    Which one should I use? Which would be better for my server?
    Thanks,
    DM :)
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    They are both 7200rpm drives so you'll see very little to no difference between the two, the Seagate has a 6Gbp/s interface but the spindle isn't fast enough to make any noticeable difference over 3Gbp/s.
    Any reason you're putting an enterprise grade drive into a home server? A WD Red 1TB would likely be fine for a home server?
  3. Dark Matter
    12 Mar 2010
    Yes a close call between them; it is just that I have both of them available left over from other projects that I didn't go through with :)
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    I don't think there's going to be any noticeable difference between them, use the one with the most warranty remaining :D
