Other Possibly NSFW: Should I pop this blister?
Discussion in 'General' started by longweight, 15 May 2013.
  1. longweight
    7 May 2011
    3 weeks ago I spent two days on site in my site boots which are slightly too loose. The result of doing this is the blister shown below. I have had it for 3 weeks with no change, I have been wearing sandals the whole time to give it some room.
    It doesn't seem to be relenting so I am not sure what to do as it is likely that I will have to wear some smart shoes for a day or two to some meetings in the near future and it is very painful to do so with this thing!
    I have searched the web and apparently I shouldn't pop the blister but... what do you think?
    http://i.imgur.com/CM7i6mK.jpg
    lp rob1 likes this.
  2. jinq-sea
    15 Oct 2012
    I'd pop it and then shove a blister plaster on it. Usually works for me!
    EDIT: Make sure you sterilise whatever you use to pop it though, and then keep it clean.
  3. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    DO IT! DO IT! DO IT! DO IT!
    but it has to be live streamed on this forum somewhere :)
  4. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    The day longweight realised his dependence on this forum was too great. Be a man, make your own non-technical related decisions
  5. longweight
    7 May 2011
    Oh come on that is a bit mean!
  6. TheStockBroker
    19 Nov 2009
    I can see how that might be misinterpreted. It was a lighthearted rib because you're grossing me out right now :)
  7. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    If it's got anything in it, you've gotta do it. It's not going to go away; the body doesn't have any way to reabsorb the fluid, nor would you really want it to since it's there for antiseptic purposes (and I would guess is now septic to some percentage, if it's done its job).
    Also wow, this just ruined my breakfast.
  8. longweight
    7 May 2011
    Good advice, I will go at it tonight and post a picture of the results.. or maybe not....
  9. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    I haven't been man enough to click the picture. I applaud that you didn't hot link the image, as by the time I had decided that I didn't want to see the inside of this thread I had already clicked it, and had the image been hotlinked it would be too late and my eyes would have seen what I think they never want to see (After reading the comments above).
    But yeah, pop it! And buy some nice boots that fit better :)
  10. longweight
    7 May 2011
    I didn't want to upset anyone with a hotlink image :)
    My boots are great and very comfy but I didn't tie them up well enough and 33 hours in two days destroyed my heel.
  11. Lance
    Lance Ender of discussions.
    6 May 2010
    What you do is pop it with a needle from the floor side of the foot.
    so:
    [_____]
    There
    So that the fluid will drip out the bottom, but keep the skin on top to prevent infection.
    longweight likes this.
  12. longweight
    7 May 2011
    ASCII art that is helpful?! Rep for you!
  13. jinq-sea
    15 Oct 2012
    How long did it take you to sort that out, Lance. I like it.
    Longweight - the other thing you could pop on it once it's burst is some Hypafix - http://www.amazon.co.uk/Hypafix-Adhesive-Dressing-Retention-meter/dp/B003L87EKC
    It's good for burns and blisters etc and just stays on until the offending injury is healed :thumb:
  14. longweight
    7 May 2011
    Nice!
    I'm not sure how sore it will be as it has had 3 weeks to regrow the skin underneath...
  15. jinq-sea
    15 Oct 2012
    Aha yes - true. The skin will most likely be soft underneath though.
  16. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Pop it, soak in salt water or dab with meths, it'll sting a bit.
  17. Margo Baggins
    28 May 2010
    I have never had a blister last 3 weeks, that is also worth some credit! I didn't think they could stick around for that long.
    33 hours is 2 days is not fun at all.
  18. longweight
    7 May 2011
    Check out the picture to see the kinda blister that sticks around for that long ;)
  19. jinq-sea
    15 Oct 2012
    ...or get the blowtorch out....*
    *Don't. It's a stupid idea.
  20. Snips
    14 Sep 2010
    A rusty nail sticking out of some rotten wood should do it
