Hey Nitrix, I'm looking for a full cover block for my card. I know you have a few, but I'm not sure which one to go for >.< Mainly because I have no idea about the PCB layout. I don't want to run the risk of frying the card. If you could link me to the ones that should fit, that'd be grand. Ta, mars.
Thanks for the speedy reply!! This is the only sticker on the card: Hopefully that'll help you!! Thanks EDIT: Just found the box, hopefully this can help a bit more?
its not looking good EK and Aqua-computer have said no - best option might be core only block and ramsinks
Thought that would be the case, thanks anyway, I'll have a look at core only blocks then Cheers man. +rep Edit: Okay, I'll rep you as soon as a spread some about.
The Enzotech Ramsinks are the best I've used http://www.aquatuning.co.uk/product...ch-RAM-cooler-BCC9-Low-Profile---passive.html The Swiftech MWC60 is pretty good but there's none in the catalogue. Also you need to always use the thicker O rings as normal thickness ones will leak. The Enzotech block slightly edges the Swiftech http://www.aquatuning.co.uk/product...zotech-VGA-Waterblock-VGA-IS-Full-Copper.html but is a bit pricey and I don't like the look of the chromed cover, I removed mine so you can see the copper. Not sure if it fits the 260 though.
