Development Zbrush, Photoshop, 3dsmax and Unreal Engine
Discussion in 'Software' started by Snips, 29 Aug 2013.
  1. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    I have a friend of mine who is going to uni to study games development. He can use the software but has no idea at all about the hardware side of things. (Console Gamer o.0)
    Anyway, I need to build him a rig on a student budget that can run Zbrush, Photoshop, 3dsmax and Unreal Engine.
    Any ideas on what is necessary for good performance of this software?
    He was going to buy a laptop but then realised it would take a while for rendering and whatnot, time apparently he wont have as I'm sure he will be ignoring all freshers activities ;)
    Thanking you all in advance for any assistance.
  2. RedFlames
    23 Apr 2009
    Seeing as this is [pretty much] what i did at uni... and considering my current rig was paid for with student loan...
    an i7 is pretty much a must [8-core AMD at a push], 8+ GB RAM, Large [1TB Minimum] HDD and [ideally] an nVidia GPU with a 1GB+ VRAM
  3. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    RAM. Lots and lots of RAM. Apart from the work machine, if he's planning on doing a lot of heavy graphic design then it might be worth setting aside a bit of money for a NAS of some kind. Whether it's a self-built machine running FreeNAS or any one of the commercially available options it up to him, but it might be nice to have a place to archive all those 3D models and Photoshop files.
  4. Snips
    14 Sep 2010
    Cheers guys, appreciate the help ;)
  5. Snips
    14 Sep 2010
    I've gone off the Enthusiast Bit-Tech Build.
    If we dropped the GFX card from a 780 to a 680, would this have an effect on the overall rendering times?
  6. RedFlames
    23 Apr 2009
    Might affect how well UDK runs and how max copes with high-poly scenes when modelling, but rendering, but as for rendering most of it is still cpu-based...
  7. Snips
    14 Sep 2010
    Thanks RedFlames, he's just been awarded a £1,000 scholarship so adding it to his existing budget will probably do the Bit-tech enthusiast build as is. I'll get it ordered and posted in the build section.
  8. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Zbrush is an awesome product
    Sent from my GT-I9505 using Tapatalk 2
  9. Tangster
    23 May 2009
    Zbrush and 3DsMAX love RAM. Especially for heavy scenes. An SSD for WIP files would also help, since the larger projects can take up a lot of space(and a lot of load time).
