Development Need help with c#
Discussion in 'Software' started by jamsand, 7 Apr 2014.
  1. jamsand
    jamsand Minimodder
    21 May 2011
    Hey bit-tech struggling to find something specific online but here is what I'm after. I am trying to list off all files inside my current working directory. Which I have working it stores all the files directories inside a string array and using a foreach loop it writes each one to the client.
    However the client only has one read.readline on the other side so the other 3 values in this case are stored in the que and creating a backlog of files. How can I make a loop that will read all the values in and display them or convert the array into a single string value that can be sent and displayed
    pastebin to code
    http://pastebin.com/4sHrHv0H
  2. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    I'm still a relative beginner with C# and don't fully understand the problem/description and haven't done anything with client/server stuff, but just a quick idea, would StringBuilder be of use?
  3. jamsand
    jamsand Minimodder
    21 May 2011
    I stringbuilder is exactly what I need by looks of it but don't understand how to use it yet
    Sent from my GT-I9300 using Tapatalk
  4. jamsand
    jamsand Minimodder
    21 May 2011
    So after little more digging it appears you can concatenate an array into a single string but I'm not sure how that's done
  5. Cerberus90
    23 Apr 2009
    This looks like it might cover it quite well.
    Shows the String Builder and the string.Join() function.
