Silly Question
Discussion in 'Watercooling' started by Lance, 18 May 2010.
  1. Lance
    Lance Ender of discussions.
    6 May 2010
    When do you actually need to start watercooling?
    I've got a titan air cooling my unit. And as nothing i have seems to tax my pc enought to need to overclock it, i'm not sure i see the point. I tend to run around 42 degrees. I bought a overclockers setup so i can quite easily turn on overclocking.
    That said water cooling does look the nuts, and therefore i want it. It comes after a 5870 and a Intel SSD on my shopping list.
  2. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Watercooling generally allows you to overclock further, makes for a quieter system and like you said it looks good.
  3. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    it looks fun and interesting to do. i'm bored of buiding a PC that has some form of aircooler bolted onto it nowadays. at least with WC, you can pick and choose how it looks and what it cools.
  4. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    You can watercool for many many reasons:
    1. Perfomance - getting the best overclocks and most from your components
    2. utter silience - passive kits
    3. Looks - just to make your pc / mod look good.
    4. because you can
    :rock:
  5. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    The only reason you really need :thumb:
  6. aquatuning
    5 Jul 2006
    I like to mix 3+4 personally :p
  7. Lance
    6 May 2010
    Yeah i would doing it for 3+4. It would be nice to have one of those pc's that people go "oooooo" when they see it. Unfortunatly that means that watercooling is going to remain slightly lower on my list of things to buy.
  8. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Alots of work. I found a massive case is the first step :p
  9. Wing Zero
    28 Apr 2010
    Your HAF932 is plenty big enough for a WC loop. you could fit a few radiators in there easily.
    Now try working with a Antec 1200, and you'll find out that a big case does not necessarily fit watercooling with ease
  10. aquatuning
    5 Jul 2006
    I love working with the HAF 932 its a great wc case!
    As fot the Antec cases :wallbash:
  11. Bloody_Pete
    11 Aug 2008
    Apart from the HAF's tendency to vacuum up dust!!
