Hi, I’m new to water cooling so I’m not 100% confidant in the build but there are a couple of parts that I do want to use but I’m not sure what the spec’s I would need to use i.e barb size etc.. So I guess if I list the parts and the details of my loop could you help me build a list of parts I can purchase Many thanks
Yes sorry for the late reply, The only part I have at the moment is the Laing DDC 1T pump, I am looking for a single loop to cool only the CPU. I am looking to put this inside a Cosair 700D case so would like an internal solution. My main needs are Triple Rad CPU cooling block for AMD Phenom IIX4 965 BE Barbs (Compression fittings if poss) Tubing Res Please let me know if you need any further info
triple rad for the CPU only ... that's total overkill, unless you want to watercool your GPU(s) later. A single 120mm rad will be enough for the CPU. That kit would be nice I think : http://www.aquatuning.co.uk/product...EK-KIT-H3O---Supreme-LT-120-Cu-Intel-AMD.html
Something like this: https://www.aquatuning.co.uk/shopping_cart.php/showkey/a86324c74bf4f2b4c0f670c55883f805
