Phobya Cases Sneak Peek!
Discussion in 'Watercooling' started by aquatuning, 10 Jan 2012.
  1. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    Hi Guys,
    Just a sneak preview of some of the up coming cases from phobya :)
    The Tower - Phobya UltraBig Water V.1 Black Edition Case
    The first really purely designed for water cooling housing Phobya WaCoolT UltraBig Water Case Black!
    The manufacturer Phobya is a luminary in the field of water cooling and modding. So it was only a matter of time until the series of different models, manufacturers do not meet the requirements of the manufacturing consortium. We developed a basic concept of modular design which constantly adapted according to customer requirements and evolving.
    The housings are made ​​of 1.5 mm thick steel and therefore extremely durable, which is frequent in the water cooling conversion extremely beneficial. Each of the black powder-coated parts, ie, front & rear, interior, side panels, everything can be removed and remounted. No rivets fastened with M4 screws everything! This allows modders a new dimension of a housing modification.
    But not only are case modders in this system have their fun. These cases are just the beginning, because all parts can be replaced according to your wishes. It may be a side panel with Plexifenster, the lid should be a different radiator installed, the back should be equipped with 2 power supplies, all of these optional components are available from the manufacturer as soon Phobya commercially.
    Individually, the front! Supplied have been omitted on purpose to push buttons or switches. Each two 19mm holes for it. These are optimized for the variety of commercially available switches. Who swears to quality is also suitable probe of Phobya. Of course there'll be too different front options to make this in the future can be as individual as possible.
    The case is in spite of the completely modular design vormoniert!
    Water cooling is the issue that was brought in these types of housing in the focus. Thus, hose and cable penetrations were optimized dehingehend. All rubber holes for hoses and cables can be removed to install there Fillport, 19mm Lochbohrgung. Different radiator, reservoir and pump assembly devices are integrated. This case is the first of its kind in as much detail what vervollkommned on water cooling!
    Special features of the Phobya WaCoolT mATX-1 Case Black case:
    radiator or fan assembly:
    Back: 1x 120 fans (no 140s)
    front: 1x 200 Radi, 1x 280 or less, 1 x 240 or less - the whole assembly for hard drives can also be move backwards and screw because of different radiator sizes
    cover: 1x 400 Radi, 1x 480s or smaller, 1 x 420 or smaller, 1 x 200
    Floor: 1 x 400-Radi, 1x 480s or smaller, 1 x 420 or smaller, 1 x 200
    shelf: 1 x 400-Radi, 1x 480s or smaller, 1 x 420 or smaller, 1 x 200
    side wall to the right: 1x Nova or Super Nova can also be mounted with Nova box
    side wall to the left: 1x Nova or Supernova mounting option ONLY with Nova Box and Shroud 1x 200 or 180 fans
    -Schlauchdurchführung/Fillport:
    2x back , 19mm opening
    4x top, 19mm aperture
    6x hose guide, 19mm opening
    , 2x mounting device pumps on the shelf:
    internal, middle, underneath the motherboard
    M4 threaded holes
    compatibility: eg Laing, Laing D5, Eheim 1046 (HPPS, Aqua Stream, Watercool 12V), Eheim 1048, Magicool 12V DC 260 and DC 400 Phobya, EK-DCP and 2.2 DCP 4.0
    -reservoir
    internally, alternative to the radiators
    outside, the back
    5X Slotin holes for mounting possibility of Conditions (tube up to 400mm)
    -ON/OFF and reset
    the left and right in the front 19mm hole size
    Mainboard Compatibility:
    ATX, mATX (Micro ATX), eATX, μATX
    graphics types of length up to 400mm, according to slot distance 580mm
    wheels as feet
    -10x 5.25 "drive bays with 9 front-panel
    -9x 3 , 5 "drive bays
    , 3x power seats - of which 2 to 80 with cover and fan assembly option, length 400mm
    Technical details:
    Material: Steel
    Color: black powder coated
    Dimensions (L x W x H): 585 x 243 x 760mm
    Weight: 22000g
    A multilingual, illustrated assembly instructions can be found here. (To follow)
    Delivery:
    1x Phobya WaCoolT UltraBig Water Case Black
    mounting hardware
    Allen
    The HTPC - Phobya Water mATX Case Black Edition
    The first really purely designed for water cooling housing Phobya WaCoolT mATX Case Black one!
    Water cooling is the issue that was brought in these types of housing in the focus. Thus, hose and cable penetrations were optimized dehingehend. All rubber holes for hoses and cables can be removed to install there Fillport, 19mm Lochbohrgung. Different radiator, reservoir and pump assembly devices are integrated. This case is the first of its kind in as much detail what vervollkommned on water cooling! peculiarities of Phobya WaCoolT mATX Case Black housing 1: radiator or fan assembly: Rear: 1x 120mm cover: 1x 240mm -Schlauchdurchführung/Fillport: 2x rear, 19mm opening 1x top, 19mm hole mounting device pumps: internally, right side, above the motherboard M4 threaded holes compatibility: eg Laing, Laing D5, Eheim 1046 (HPPS, Aqua Stream, Watercool 12V), Eheim 1048, Magicool 12V, Phobya DC 260 and DC 400 EK-DCP and 2.2 DCP 4.0 -reservoir internally, right side, above the motherboard lying tubes 4x Slotin -ON/OFF and reset the left and right in front of the 19mm hole size mainboard compatibility: htpc, mATX (Micro ATX) graphics types of length up to 370mm -feet decouple the housing -4x 5.25 "drive bays with three front-panel -4x 3.5 "drive bays , 1x power supply slot, length up to 370mm
    Technical details:
    Material: Steel
    Dimensions (L x W x H): 383 x 353 x 223mm
    Weight: 9240g
    Delivery:
    1x Phobya WaCoolT mATX Case Black one!
    mounting hardware
    Allen
  2. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
    first thing that comes to mind: How much can those wheels take? Weightwise.
  3. aquatuning
    5 Jul 2006
    a lot - the same type that's used on office chairs.
  4. KidMod-Southpaw
    28 Sep 2010
    The tower looks amazing, but too insane for my liking.
    But that MATX case looks like my cup of coffee, I bet you won't tell me how much it's going to retail for. :3
  5. aquatuning
    5 Jul 2006
    229,99 euro for the tower and 119,99 euro for the HTPC
  6. subtec
    subtec drawing boxes
    4 Nov 2010
    Pretty much what I expected.
    You have a typo in the thread title btw.
  7. aquatuning
    5 Jul 2006
    first post updated.
    These are the babies btw there bigger ones to come ;)
  8. KidMod-Southpaw
    28 Sep 2010
    BIGGER THAN THAT THING, WHY AND HOW!?
  9. aquatuning
    5 Jul 2006
    cos we can you you will see ;)
  10. zulu9812
    zulu9812 What's a Dremel?
    21 Oct 2010
    Can we say "Mountain Mods"? Quite disappointing, actually. I was expecting more. Especially with Case Labs on the scene.
  11. aquatuning
    5 Jul 2006
    Phobya tends to aim for practical affordable products so the price point here is the main thing to be aware of
  12. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    The case for my next build is bigger - Little Devil case, with room for 2 * quad 120 rad in the bottom, one quad at the top and 2 PSUs. They are way more expensive though. It would be great to see them in Aquatuning's inventory, they are built for the EVGA SR-2 and upcoming SR-X :)
    This case looks like the sort of case I might use for another build, especially as it's on wheels. Brings another meaning to "mobile computing" - I could easily take one of my folding rigs everywhere I go :):D
  13. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Nice cases, but I was expecting the Owl case from the case competition... :(
  14. aquatuning
    5 Jul 2006
    @ Debs these are SR2 compatible too :)
    @ marvin that will be coming soon.
