Apologies if this is the wrong place to post but I figured customers of Aquatuning or Aquatuning them selves might be able to help me out. Soo... I would like to enter the realm of water cooling. I've never done it before and require some help choosing parts and confirming if what I had in mind will connect together My rig is in the sig. I was thinking of 2 Rad's, one after the CPU before the GPU? Also is cooling the motherboard worth it? RAM I'm quite content on leaving it Air cooled as it's mildly warm. What I'm worried the most about is buying the wrong fittings or getting the size of hose wrong. Here is my list so far: As you can tell I'm guessing in regards to the amount of hose, anti-kink rings and coolant. I haven't got fittings on this yet as this is the part I can't quite pick, Ideally something that's easy to connect yet won't come undone. I think I also need a plan to be able to drain the loop easily as well as I plan to fit in another 680 at some point. Many thanks to anyone who replies
