I have a Logitech G700s which I bought on here nearly 4 years ago and I'm pretty certain that it's started double clicking when I'm only clicking once. I first noticed it at the weekend when I was editing some photos in lightroom and when I clicked a slider it reset it back to zero which normally requires a double-click. I've just noticed it again doing an online grocery order where I'm clicking an item once and ending up with multiples in the basket Is there a definitive way of testing this? Cheers GK
Watch something on youtube or netflix whilst clicking once every second on a file or folder. If it opens it's double clicking.
Simplest way to a definitive answer is to invert the functionality of left and right mouse button in software. If it stops happening the left mouse button is f***ed.
There are various pieces of software for windows and linux, can't recall one off the top of my head, that will allow a user to capture mouse events. You could use one of these as a tool to detect how many click you are receiving. Edit: I had one sitting my desktop GlovePIE, I use it to provide mouse look in old FPS. Not the best as it doesn't allow you to watch the actual events but you can hack it: Create a new script and paste the following in the window. Open a text editor of your choice. Click run in GlovePIE then change focus to the text editor (I tested it with Notepad++) and start clicking your mouse. you should see the letters "l", "m" and "R" appear after each click. Once done don't forget to stop GlovePIE. Code: Key.L = Mouse.LeftButton Key.M = Mouse.MiddleButton Key.R = Mouse.RightButton
