Watercooling Modded Corsair H60 with reservoir - still testing
Discussion in 'Hardware' started by jizwizard, 5 Nov 2011.
  1. jizwizard
    jizwizard Modder
    24 Dec 2010
    right as title suggests i have modded my h60 to include a swiftech. pretty straight forward.
    temp wise im still testing/bleeding the system will update shortly
  2. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    You really do have lots of time to burn don't you! Nice work though, I'll watch this with interest. :D
  3. jizwizard
    jizwizard Modder
    24 Dec 2010
    i wish theres not enough hours in the day.
    just doing some more leak testing and bleeding as i speak. i have removed it from the case to do this
  4. MrDomRocks
    MrDomRocks Modder
    5 Sep 2011
    Hmmm looking good there dude, though I'm jelous I want a 2nd GTX 570!!
  5. Mongoose132
    Mongoose132 Duckmad
    23 Aug 2007
    Why? :s
    Whole advantage of a prebuilt sealed loop is to not have a res :p
  6. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Larger quantity of water should in theory lower the temps.
    Whether the difference in quantity is large enough to produce a temp difference is yet to be seen.
  7. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I'll be suprised if it makes any difference really.
  8. mrbungle
    20 Sep 2004
    I think its been noted in past mods it helps a few degrees
  9. Bloody_Pete
    11 Aug 2008
    Is it really worth it though?
  10. Ljs
    Ljs Modder
    4 Sep 2009
    Bit of fun, shave off a few degrees - isn't that the point of tinkering with PCs anyway?
    That is not the spirit!
  11. jizwizard
    jizwizard Modder
    24 Dec 2010
    right after initial testing idle temp is down to 27c from 32c. stressed temp is 50c down from 63c. so yes it has dropped the temps a bit. but as im going fully watercooled i thought what the heck chop it up. used the original fluid that was in the corsairr loop along with distilled water. with the loop and res i estimate twice the fluid was used.
  12. xboxexpert
    xboxexpert What's a Dremel?
    6 Feb 2012
    Would you be able to tell me which port out of the waterblock is the in port and which is the out port. I'm going to do this mod to add liquid cooling to a video card block and I'm wondering which is the input and output of the pump on the cpu block.
  13. jizwizard
    jizwizard Modder
    24 Dec 2010
    Output on top mate
  14. Jipa
    5 Feb 2004
    Oh wow how didn't I think of this! I drained my H100 not so long ago and been wondering how on earth do I get it filled back up again :) Adding a small res should sort it, and while I'm at it some custom length hoses wouldn't hurt, either.
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Interesting.
    My res is 500mm heatsink choob from XSPC. A monster that sits vertically by window next to radiator.
  16. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Haha you've given me a crazy idea... Instead of RMA'ing my h60 make a cycling reservoir of mayham particulate fluid external to my case on my desk :) just for fun haha
    *maybe*
  17. xboxexpert
    6 Feb 2012
    Can you please be more specific on which is the input and which is the output barb on the heatsink. Perhaps edit a picture showing the flow pattern. I'm going to do a ridiculously small form factor case liquid cooling mod with this unit tomorrow. I'll post some pics after I'm done.
  18. towelie
    towelie How do I Internet!!
    1 Sep 2011
    Wow thats pretty cool, Jizzwizard(love the name and DP by the way) do you know whether the pump is attached to the radiator or the CPU socket?
  19. jizwizard
    jizwizard Modder
    24 Dec 2010
    sorry got it the wrong way. the output is the bottom one. the pipe that goes from the pump assembly to the rad. if you look at the pics youl see what i mean
    towlie the pump is built into the cpu block
    bulldogjeff likes this.
  20. xboxexpert
    6 Feb 2012
