Build Advice E8500 VS Q9300
Discussion in 'Hardware' started by Trip.X, 27 Nov 2008.
  1. Trip.X
    Trip.X What's a Dremel?
    16 Nov 2008
    Haay,
    What do you think is better for a gaming pc.
    The E8500 (with ATI 4870)
    or
    The Q9300 (with ATI 4850)
    I think the E8500 is better, because he has a higher GHZ.
    Greetings,
    Trip.X
  2. 5hadow
    5hadow What's a Dremel?
    24 Aug 2008
    Dual Cores for gaming anyday. :thumb: So, yes you are right. E8500 is better.
    Even better is E8400 as there is hardly any difference in clock speeds but a considerable difference in price.
  3. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    go e8400, but remember to get a m/b that can hit high FSB speeds
  4. wyx087
    15 Aug 2007
    higher Ghz and also better graphics card. so e8500 + 4870.
    or e8400 + 4870 1GB, better gaming and no performance difference
  5. Trip.X
    16 Nov 2008
    I think I use the MSI Neo3-FR (1600 FSB)
    Is that 1GB beter, I thought it had no difference
  6. tonpal
    tonpal What's a Dremel?
    27 Jul 2008
    It will come into its own with large monitors.
  7. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
  8. Trip.X
    16 Nov 2008
    But, im gonna use a 20 inch.
    So i think the 512 is enough?
  9. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    yes, for that it's more then enough. If you are not going to upgrade that anytime soon, get the e8500 + HD4870 512, and boogie!
  10. Trip.X
    16 Nov 2008
    TNX everyone
