just got a new FX-8350 and installed it into my sabertooth 990fx fairly easily but i am worried that it didnt seat properly... i am using cpuid Hardware monitor and also speedfan to measure temps and im getting some pretty wierd numbers. heres my numbers... what on earth is going on... i dont want to reseat my dark rock be quiet pro unless i absolutely have to because it was a ball ache (no rear access hole in my case you see....) which one should i trust? EDIT: Just checked in the BIOS and the temp reads at 34 according to that. loldafunk?
CPUZ says 34, bios says 34, but speedfan says 62-speed fan is kinda useless half the time it must be said, do you have any other software like Asus AI suite to confirm?
