News Haswell C states raise PSU compatibility fears
Discussion in 'Article Discussion' started by Gareth Halfacree, 1 May 2013.
  1. Gareth Halfacree
    4 Dec 2007
  2. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    I got an enermax Modu 82+ and I dung really care if it has the zero load bla bla cos unless the cpu is unlocked and overclocks well and gives significant advantage over i5 2500k then I wunt be bothering.
  3. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I will be fine with my Coolermaster PSU, since I am not buying a Haswell CPU after just last month going to SB-E.
    I will however be keeping a eye on this for the pc's that I will build people using a Haswell CPU, and it's good to know Enermax will be ok to use, although I have never used one myself previously.
  4. rollo
    rollo Modder
    16 May 2008
    Surprised this has just come out now in all honesty. Most older psus 3-4 years will not be compatible so people on the older x58 and below ( the most likely upgraders in enthusaist market) will likely need a new psu if they want these power savings.
    Its a cost that most will not have budgeted for as a decent 750-850 watt psu is easily £100 makes haswell not a very tempting upgrade unless its awesome.
    £260 4770k
    £150 SLI mobo ( cheap mobos dont do sli )
    £125 PSU ( seasonic x 750 watt )
    8 - 16 gb ram price is £50 for 8gb £100 for 16gb at the moment
    Total haswell upgrade price has just hit a cool £585 - £635 if you want all its features and are on a older psu and need new memory modules.
    socket 2011 is only about £100 more for what will be a much faster 6 core cpu and a better mobo to boot.
    3930k is £463, Mobo call it £200 16gb ram is £100 now a days ( ram prices are rising fast again )
    Wonder how many people will buy it then relise they cant do most of these power savings as the psu is not compatible.
  5. Instagib
    Instagib Minimodder
    12 Mar 2010
    Surely getting a decent platinum or gold rated psu would be a better energy saving if you're all that bothered? That way, there is better efficiency when you are actually using the rig, and then when you are not, turn it off at the socket....
  6. Omnituens
    Omnituens What's a Dremel?
    5 Apr 2006
    Can't you just disable the states in the BIOS? If not, :(
    I was thinking of moving to Haswell as I am currently on a i7 920 and it's starting to show its age. But if I have to get a new PSU as well... :(
  7. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Yes, you can. ALL you lose from having an 'incompatible' PSU is that the idle state consumes a few watts (i.e. still less than current processors) rather than half a watt.
  8. Gareth Halfacree
    4 Dec 2007
  9. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    What's the exact issue that would occur with an incompatible PSU and the C6/C7 states? Will it fail and cut power to the system, or just supply power inefficiently, churning through like 10-20W while supplying 2W to the system?
  10. Gareth Halfacree
    4 Dec 2007
    While it's possible some PSUs would turn themselves off at low draw, the bigger problem is voltage ripple: without enough load on the rails, the PSU is likely to start flailing around and pumping too much voltage in one place and too little in another. Electronics don't like that very much, and while it's unlikely the ripple would be bad enough to break anything - the +12V rail isn't going to start giving 240V, for example - it would be enough to confuse the system and corrupt the contents of memory.
    Basically, if you disable the C6/C7 sleep states you should be fine - but you'll be missing out on one of the new features brought about by Haswell. Like I say in the article, though, it's a bigger problem for battery-powered devices.
  11. coyote
    coyote What's a Dremel?
    14 Dec 2004
    I guess using less power is a good thing, but having to buy a new PSU as well to take advantage of it! That's almost like Intel shooting themselves in the foot. I don't think I'll be upgrading to Haswell any time soon.
  12. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Wait, so although my Revolution 85+ has the DC-DC converter its not supported...?
  13. Gareth Halfacree
    4 Dec 2007
    No, your Revolution 85+ will (should?) be fine: Enermax has, for obvious reasons, only provided a list of current PSUs which it states are compatible. 'Cos, y'know, they want people to buy a new PSU.
  14. ch424
    ch424 Design Warrior
    26 May 2004
    I've already had this problem on my system - I've got a CX380 and it wouldn't boot my APU system because it didn't draw enough current. I had to plug three fans in just to trick it into working!
    How long until we see firmware updates for PSUs to fix this sort of thing?
  15. Phil Rhodes
    Phil Rhodes Hypernobber
    27 Jul 2006
    Annoying. I just bought a decent Corsair power supply. I have an 8-disk RAID10 in the same box; might that be enough of a buffer load, or are they concerned about the 3.3V line?
  16. Anfield
    Anfield Multimodder
    15 Jan 2010
    Its about the 12V2 exclusively used by the Cpu and nothing else, so no, other HW won't help you get over the minimum, according to here you may be fine with a Corsair Psu:
  17. ffjason
    ffjason What's a Dremel?
    27 Jul 2009
    PSU's don't have "firmware". You will not get a firmware update for your PSU unfortunately.
  18. ch424
    26 May 2004
    I meant that in the future (a few years?) they might have a microcontroller driving them because it'd be simpler/cheaper than having several power management ICs.
  19. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    Not really seeing this as an issue as far as desktop PSUs go. While it would be a novel idea, especially the connected-sleep sort of deal, your average enthusiast isn't going to much care about the difference between .5W and 4W.
    At least in the Windows world, my experience with sleeping a PC has never been all that great anyway. It's Windows - you either leave it running always and reboot when it starts getting flaky, or shut it down every night so it doesn't get flaky (and chew up your power bill, to boot.)
    I'd be surprised if the major PSU OEMs and ODMs weren't already aware of the issue and will have it addressed by the time Haswell has actually dropped (for those that haven't already handled it, like Enermax.)
    All in all, from what I've heard so far, Haswell is a bit less exciting than I'd expected, from a practical standpoint. From the engineering, super hardcore nerd point of view, it's exciting with the new arch and all. But it's definitely diminishing returns - if you aren't a bleeding-edger and you're at least on SB, doesn't seem worth the cash. I'll reserve judgment until benchmarks start coming out, but it seems less exciting than it did at first blush, all those months ago, at least in desktop-land.
  20. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    It's not meant to be exciting for desktops! It's meant to be exciting for mobile devices - tablets and laptops with Haswell chips will get better battery life, massively better iGPUs and other hardware-level features like Connected Standby which should allow Haswell devices to sleep like phones, saving power while staying connected. Intel are focusing almost exclusively on mobile because that's exactly where the money is!
    We desktop enthusiasts (or even just desktop owners) are fading away nowadays - the vast majority of people don't need a desktop at all now. Heck, if I didn't game a lot or run stuff like folding/litecoin mining, my needs would be served almost completely by the 15 inch retina MBP.
