Other Steam converting game data
Discussion in 'Software' started by Xir, 24 Nov 2012.
  1. Xir
    Xir Modder
    26 Apr 2006
    Hi,
    I haven't been paying attention for a few months.
    When I start a game, Steam tells me
    "Converting game contents into a new format"
    What is this about?
    Regards,
    Xir
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
  3. Xir
    Xir Modder
    26 Apr 2006
    Thanks....
    It takes ages on my machine, which is NOT great.
  4. Bob1234
    Bob1234 What's a Dremel?
    30 Jul 2008
    Speed is probably a combination of free RAM, CPU speed, hard drive speed and level of drive fragmentation.
  5. Igniseus
    Igniseus What's a Dremel?
    5 Mar 2006
    Its a one time job per game and future downloads wont need the convert, so it will soon be a thing of the past. And on the positive side it means whenever you get a game update it wont be as massive, for example i believe many Unreal Engine 3 based games had huge patches, even if there was 5 fixes it could be 500+ MB.
  6. Xir
    Xir Modder
    26 Apr 2006
    Which are all Sh*te in mine. :D
  7. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    There is no positive side to converting Chime, it's a game that no longer gets dev support so will never be updated and when you convert it you lose all save data.
    RAGE! :wallbash::wallbash::wallbash:
  8. Xir
    Xir Modder
    26 Apr 2006
    *sigh*
    I suppose I'll just redownload everything on the new machine when it arrives (eventually), was hoping to avoid that, my ISP will probably throttle me if I completely redownload my steamfolder
  9. CrazyJoe
    CrazyJoe Modder
    4 Aug 2010
    I've no idea how it works but only some titles need to be redownloaded, some only need to be partly downloaded and some don't need a download at all.
