Scratch Build – In Progress ThermalTake P5 MOD/HYDRA by Wrathier/Aquatuning
Discussion in 'Project Logs' started by Wrathier, 8 Feb 2016.
  1. Wrathier
    Wrathier What's a Dremel?
    3 Feb 2016
    First I'll start out by showing my gratitude to http://www.aquatuning.de/ as they have sponsored my water cooling parts for my setup. Thanks a lot Team. You are awesome. I'll also like to say thanks to a friend @ Modz by Donni.
    For the rest of you I hope you will enjoy the build and perhaps get some inspiration. I know I will. :)
    The build will contain the following hardware:
    • Rampage V Extreme
    • I7-5960X 8 Core / 16 threaded Extreme Edition CPU
    • KLEVV CRAS RED 3000MHz PC-24000 ram modules 32GB
    • Intel SSD 750 Series 1.2TB NVMe PCI Express SSD
    • SLI EVGA GeForce GTX 980 Ti Superclocked+ ACX 2.0+
    • 2 Kaze Q fan controllers
    • Corsair AX1500i to power the "RIG"
      [*]Alphacool NexXxoS XP³ Light - Brass Black Chrome
      [*]Alphacool NexXxoS Monsta 480mm
      [*]Alphacool Eisbecher D5 250mm Acetal
      [*]Alphacool Eiszapfen 2-way ball valve G1/4 - Deep Black
      [*]Alphacool VPP655 - G1/4 inner thread including Eisdecke D5 - Acetal V.3
      [*]Alphacool NexXxoS GPX - Nvidia Geforce GTX TITAN X / GTX 980 Ti M01 - incl. backplate - black
      [*]Alphacool GPX SLI Connector - Dual
      [*]Alphacool HF extension G1/4 to G1/4 20mm - Deep Black
      [*]Alphacool HF 19/13 compression fitting 90° revolvable G1/4 - Deep Black
      [*]Alphacool HF 19/13 compression fitting 45° revolvable G1/4 - Deep Black
      [*]Alphacool HF 19/13 compression fitting G1/4 - Deep Black
      [*]Aquacomputer Double Protect Ultra
      [*]Masterkleer tubing PVC 19/13mm
    Awesome. The set of parts from http://www.aquatuning.de have arrived. Time to get serious about the look of the machine. - The side panel just got replaced so the pictures with the electronic decal etc is no longer existing.
    First I'll like to show the http://www.aquatuning.de parts:
    Secondly I'll like to show the hardware and some other packets containing hardware.
    Ram have been replaced so no Corsair and no Corsair fans.
  2. Wrathier
    3 Feb 2016
  3. Wrathier
    3 Feb 2016
    I will not use the PCI-E Risers.
    :thumb:
  4. Wrathier
    3 Feb 2016
    So after a little time with the radiator, I finally got pretty satisfied except for a few air bubbles witch I'll fix:
  5. Wrathier
    3 Feb 2016
    Mod of radiator.
    Here is the radiator from another angle. As you probably clearly see, the mod is very reflective, but I doubt the light from the fans will shine it much up. I hope for just a little though:
  6. Wrathier
    3 Feb 2016
    Ok today I started mounting:
    After a little thinking and tinkering I got the pump connected with the reservoir and the radiator mounted.
    I also finished the "mod" I wanted to do on it and I think it turned out ok.
    Now I need to have a hole made in the reservoir plating stand, so I can access the speed of the pump more easy than dissembling everything and so on. But here is what I got done today:
    Again, thanks for watching. :clap:
  7. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Love me the P5 chassis! Subbed! I put a white marble wrap on mine.
  8. hero1
    hero1 Minimodder
    18 Oct 2013
    Another P5 build/mod..subbed
  9. Wrathier
    3 Feb 2016
    Today was hard. I disassembled the build from my Corsair 780t chassis and got the hole fixed in order to gain access to the pumps speed more easily and installed the AX1500i.
    Tomorrow I'll install the Rampage V Extreme and probably also the graphic cards and my hard drive.
  10. Wrathier
    3 Feb 2016
    Okay so I decided it was time to get this done.
    I moved the PSU back as much as I could in order to get a bit more room.
    Since the ASUS RAMPAGE V EXTREME is a bit large for the chassis I experimented a bit, but remade a few times asked a lot of questions and so on.
  11. Wrathier
    3 Feb 2016
    Got creative and insecure about how the side panel should look.
    The side panel is still a work in progress.
  12. Wrathier
    3 Feb 2016
    Final routing will soon be present in the machine.
    :thumb:
  13. Wrathier
    3 Feb 2016
    Remade the build again.
    Remade.
  14. Wrathier
    3 Feb 2016
    Got home, started rerouteing the loop.
    Current routing of the hoses. Should be changed here in the weekend.
  15. Wrathier
    3 Feb 2016
    Thanks Aquatuning and thanks for watching everyone.
    :thumb: Without you this would not be possible.
    and thanks to everyone else as well. :thumb:
  16. Wrathier
    3 Feb 2016
    Work in progress.
    The window is the thing bothering me. It's blocking the view to the vital parts of the machine and that needs to be sorted, but right now I got what I got.
  17. Wrathier
    3 Feb 2016
    Work in progress.
    :read: :thumb:
  18. amagriva
    amagriva Minimodder
    13 Jun 2009
    Gorgeous build!
    I don't like/understand the stripes/decals on the glass/acrilic....I see them only as a nuisance/obstruction between the "goood stuff" and the eye of the watcher
    Ciao
  19. Wrathier
    3 Feb 2016
    Thanks bro means a lot. I'm really working on something for the window. I agree that the sight is obstructed.
  20. Wrathier
    3 Feb 2016
    A few better pictures.
    I managed to get a few good pictures, I'll still do it better when I get the GFX's under water, but for now, I hope you'll like this:
    The radiator mod:
    Cheers :)
