Windows A Beginers guide to setting up mIRC
Discussion in 'Software' started by Forsaken, 23 Jun 2002.
  1. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    Step 1:: Get A Client
    Can get one here. (1.14MB)
    Step 2:: Install And Set Up The Client
    Just install it the same way as most other apps. When you first run mIRC you will get a box like this::
    Un tick the box then close the window.
    Then you get this::
    Enter your name (use you Nick if you are funny about giving out your name), and email address. Now enter the nickname you want to have in the Nickname box, and a second one just incase the first is allready taken in the alternative box.
    Next we need to choose a server to connect to. Click the add button at the top.
    We get this loverly little box up::
    Now we need to pick a server from this list.
    Try to choose one local to you, not that it matters, just helps the speed of things. Give it a name you can rember in the description box, and type its address in the "IRC Server" box.
    Hit add.
    Should be back to this screen now, with the server you just set in the second drop down menu.
    Next expand the connect part on the options menu on the left, then pick options. tick the "connect on start up" and "reconnect on disconnection" boxes.
    untick the "popup connect dialog on startup" box.
    Click back on connect.
    Hit "Connect to IRC Server", and wait untill it has finished logging you on to the server. After a while you will get this box.
    Untick "pop up folder on connect"
    Click add again. You will get this window
    In the channel box type #bit-tech
    Leave the password box blank
    Type "Bit-Tech Chat" in the description box
    Tick "Join channel on connect"
    Hit ok, then hit the join button halfway down the window
    Enjoy you stay.
    Step 3::
    Talk.
    (mIRC should go stright to Bit-Tech Chat next time you start it up.)
  2. RTT
    RTT #parp
    12 Mar 2001
    I can see this being of use to n00bs in the Software forum :)
    Nice little guide Forsaken! :cooldude:
  3. Hiren
    Hiren mind control Moderator
    15 May 2002
    Great post really helped a lot :lol:
  4. K
    K 528491
    31 Oct 2001
    Glad you knew what to do with it, I was lost :p
    Nice one dude :cooldude:
  5. KypD
    KypD What's a Dremel?
    8 May 2002
    thanks a lot! i'd gotten mIRC thinking how great it would be to talk to a lot of people i know from certain channels without having to go to the website and using it's chat applet...
    but then i had no idea how to use it! very nice indeed. :D
  6. Morphine
    Morphine weeee!
    23 Feb 2002
    how do i use IRC in TRILLIAN? SOMEONE PLEASE
  7. batsman
    batsman the quiet one
    14 Nov 2001
    nice guide.
    Any chance of a list of commands and what they do?
  8. hk
    hk Powered By Duracell
    4 Jul 2002
    Well you could always just hit F1 and look in the help file ;) or do "/quote help" and the server will spit back a load of commands.
    Also for a kick ass network try irc.xnet.org ;)
    heh heh
  9. relix
    relix Minimodder
    14 Nov 2001
    Great guide, one little error though:
    mIRC is the client, IRC is the protocol, you can't get "a mIRC client", you just get "mIRC", or "an IRC client"
  10. hprcrazyguy
    hprcrazyguy Minimodder
    31 Dec 2001
    yeah, how do you get irc to keep the server and all the settings in trillian, I can get connected but if I close out trillian it resets my irc settings. :(
  11. Aswethinkweis
    Aswethinkweis Banned
    9 Dec 2002
    simple answer: dont use the trillian IRC client, heheheh
  12. Morphine
    Morphine weeee!
    23 Feb 2002
    I dont really use IRC all that often, so I dont feel like having a whole seperate program for it. that and I like trillian. Its convenient once you work out all the settings an stuff.
  13. ernie
    ernie What's a Dremel?
    27 Jan 2003
    helped me out, but then im a complete newb at this mIRC thing
    now only if i can figure out how to d/l stuff :confused:
  14. Sid
    Sid Banned
    13 Mar 2002
    ah reminds me of my mIRC scripting days. that was a lot of fun. must go back to it sometime.
  15. Raleign
    Raleign What's a Dremel?
    20 Apr 2003
    This was great! Thanks a lot! :)
  16. craigey1
    craigey1 Minimodder
    13 Jan 2003
    Can someone explain how to setup Mirc with an ADSL Router. I just can't get the thing to connect.
    Thanks
  17. ST8
    ST8 What's a Dremel?
    14 Feb 2003
    mine works as is with my router, however if yours doesnt try forwarding ports 6667-6700, there the major ports irc uses...
  18. Froggy
    Froggy What's a Dremel?
    10 Jun 2003
    the IRC in Trillian sucks. i have Trillian Pro and i have used both mIRC and Trillian's IRC and i can tell you easly not to use the Trillian IRC. I am using Trillian right now and i love it so dont think that im bashing it. im just bashing the IRC.
  19. jcoquillon
    jcoquillon What's a Dremel?
    9 Jul 2001
    IRC is winnville to be perfectly honest. I spend more time there than in any forums. With practice and experimentation you can do very spinkee things with it like aliases and logging all conversations.
    Trillians blows farm yard animals in abundance when compared to stand alone applications. Windows Messanger + mIRC is all you'll ever need
  20. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    messenger sucks
    trillian and mIRC is all you need :p
    nnscript is a decent all round script too, easy to setup and stuff, and makes everything look better :D
