Watercooling Is this pre watercooled case good?
Discussion in 'Hardware' started by streetuk, 18 Feb 2011.
  1. streetuk
    streetuk What's a Dremel?
    3 Jul 2009
    http://www.overclockers.co.uk/showproduct.php?prodid=WC-023-OE
    Spec:
    Mainboard : Asus P8P67 DELUXE
    Chipset : Intel Sandy Bridge
    Processor : Intel Core i7 2600K @ 3400MHz OC @ 4.5Ghz
    Physical Memory : 8192MB (4 x 2048 DDR3-SDRAM )
    Video Card : NVIDIA GeForce GTX 580
    I'm wanting to cool the GPU and CPU, would this pre watercooled case be good?
  2. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    It's a great case for watercooling. Although I think a 360mm rad may not be enough (not sure on this, don't know what the heat output for these new CPUs and GPUs are like). May be worth buying all the parts separately. May work out cheaper.
  3. Big Elf
    23 Apr 2009
    It's not a bad price although as mars-bar-man has suggested it's worth pricing up the components separately. The block and radiator are very good and the pump/reservoir combo is OK although I'd be concerned that pump vibes would be transferred to the case.
    A triple rad should be OK for that heatload although you'd have to add in another £65-75 for an 580 waterblock.
  4. streetuk
    3 Jul 2009
    Thanks, the reason why I like it is it's already set up and leak tested.
  5. streetuk
    3 Jul 2009
    I read on the OcUK forums that its around £20 cheaper than to buy it all separately.
  6. mars-bar-man
    17 Apr 2009
    That maybe the case, but if you want to add the GTX580 block, you'll have to drain the system, then add more tubing etc. Then leak test your self.
    See, already working out cheaper, all they're doing is removing some of the fun of building it.
  7. streetuk
    3 Jul 2009
    Is it too difficult to build a water cooled system? I've built my last two pcs myself, it didn't go as smooth as I'd hoped but they were fine in the end.
  8. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    I'd say that if you aren't quite confident enough, going with the pre-setup case is a great idea. The kit used is good, the case is great. A 360 rad wouldn't be enough for all of those components, however, the 2600K will have no problem getting to around 4.5GHz on air, so if you were to take the processor block out of the equation and make your own setup with water cooled graphics cards only, you should be good to go.
  9. mars-bar-man
    17 Apr 2009
    It's not difficult to do at all. Get stuck on something? There's a wealth of knowledge out on the web. A lot of it right here as well.
    You just need to double check, then recheck everything. Seems daunting at first, but it's totally safe as long as you're sensible.
    http://forums.bit-tech.net/showthread.php?t=201254 <- Read that. Then read it again.
    I threw myself in at the deep end when I built my first WC rig. Read a few guides then threw myself into it. Not a single issue.
    Can't get enough of watercooling now, ITX rig fully WC'd will attest to that!
    streetuk likes this.
  10. mrbungle
    20 Sep 2004
    somthing that has been leaktested then stuck in a box and lugged around by a courier needs leaktesting again tbh
  11. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    QFT. I wouldn't trust anyone else's leak testing anyways.
  12. Big Elf
    23 Apr 2009
    The TDP of the GTX580 is 244W and an overclocked Sandybridge maybe around 160W (guessing) so a triple rad should handle that and have decent temps with 1800 rpm fans.
  13. streetuk
    3 Jul 2009
    That's what i was worried about. Think I'll just do this myself when I finish uni and i have loads of spare time lol
  14. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    That rad will be fine :) it's comparible to a XSPC RX 360, and a guy on here (Dead Beat I think) uses one to cool 2 580's, so it should easily cools a SB and a 580 :) What I'd do it pop them an email and ask for a price including a GPU block. The problem is that then you'd have to fit the block to the card... urg, hassle. So one way will be difficult, the other, opening up the loop to put in your own block, voids the warranty which defeats the purpose of buying a prebuilt kit like this.
    I just added it up (using their own site, but stuff will be cheaper else where) and you save £40, not including the fluid... Which is not shown on their site, which worries me... Distilled water can be had for £4 for 5L though. So it's a saving of £36 from the stock on their site... Make of that as you will... (I've never bought watercooling gear fron them as otherplaces are cheaper).
    And thanks to mars-bar-man for linking to my threasd, I'm glad people appreciate it :)
  15. lamboman
    25 Jul 2006
    My bad, I thought it said SLI xD
    Don't listen to me :D
  16. streetuk
    3 Jul 2009
    I think Overclockers are quite good with custom builds, I wonder if they'll add the GPU block for me so I don't have to do it. The more i say things like that makes me think more and more that i want to do it myself :wallbash: I'll see what they say anyway.
    Thanks everyone. :D
  17. Big Elf
    23 Apr 2009
    At some point, 6-12 months down the line, you're going to have to drain and clean the loop so it helps if you know how it's all put together and the simple stuff like refilling and bleeding. Although it may appear daunting at first it's quite straightforward and you can just take your time with it.
  18. streetuk
    3 Jul 2009
    Has anyone had any experience with a silverstone FT02B with watercooling? Thats my current case, would prefer it if i didn't have to spend money on a brand new case again. It's not too much of a problem though, I wanted to turn my old build into a server so i could always put that in my FT02B and get a new case for my new sandbybridge build.
  19. Big Elf
    23 Apr 2009
    I think you'd have to use an external rad with the FT02 and probably have to drill tubing holes somewhere in the back although after a quick look at some piccies it might look untidy.
  20. streetuk
    3 Jul 2009
    Is the Silverstone TJ07 as good as they say Big Elf? Been on custom pcs crazy but cool pc build for years! (seems like it anyway)
