Modding Tapping in 2mm aluminium
Discussion in 'Modding' started by Parge, 31 Jan 2013.
  1. Parge
    16 Jul 2010
    Guys, just need a tap and die for a scratch build.
    Having never used one before, would I be ok using it to tap 2mm aluminium, and would this one do the job?
    Ta :dremel:
  2. jrs77
    jrs77 Modder
    17 Feb 2006
    It's very basic, but it'll do the job. 2mm aluminum is perfectly fine for tapping aswell. I used 1.5mm aluminum before and there was no problem tapping it either.
    Just make sure that you don't buy pure aluminum as it's very soft. 6061 or 6082 is what you're looking for.
  3. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    and a can of wd40
  4. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    And remember, go slow
  5. Atomic
    Atomic Gerwaff
    6 May 2002
    Firstly try it out on a couple of test piece to make sure you get the hang of it.
    'half turn forwards quarter turn back' to quote my engineering tutor - helps clear any swarf out of the tap so you will get a cleaner thread at the end :)
  6. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    or go and get some flush nuts and press it into the holes...
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    What size fastener did you want to tap it for? For larger/coarser threads, threaded inserts might give you better results. 2mm is kind of thin.
  8. Guest-279805
    Guest-279805 Guest
    I've done a bit of tapping in 2mm aluminium recently, and I experienced the opposite to what Stuey suggested - my smaller threads came out worse! Granted, I only tried M3, M4 and M5.
    The M3 worked, but after putting a bolt in and out several times, the threads wore away - they were too small to be able to stand the bolt being tightened. M4 worked perfectly, although eventually it might do the same as M3 threads. M5 was almost the largest thread I would want to try - maybe M6 or M7 would be the limit. Eventually you wouldn't have enough threads in the aluminium to hold the bolt - the M5 bolts were a little wobbly as-is.
