Build Advice Advice requested please
Discussion in 'Hardware' started by dev00790, 30 Jun 2013.
  1. dev00790
    dev00790 Pure chocolate. Pure Power.
    23 Apr 2009
    Hi
    Some advice needed please:
    Budget: £150 - £200
    Main uses of intended build: Gaming, and general use
    Parts required: Mobo, Memory, Processor
    Previous build information (list details of parts):
    ASUS P5N-D mobo
    4 GB Corsair DDR2 memory
    2 x Samsung 500GB HDDs
    Intel Corer2Duo E6850 Processor
    MSI GTX 560Ti graphics card
    Monitor resolution: 1680 x 1050
    Storage requirements: None - using existing HDDs
    Will you be overclocking: no
    Any motherboard requirements: SATA 3, Nvidia chipset, 5 USB (or more), around 3 fan headers
    Extra information about desired system: N/A
  2. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    Preference on AMD or Intel? Or not bothered? And nvidia don't make chipsets for Intel desktops anymore or AMD ones for that matter.
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
    AMD A10-5800k + board and some fast ram
    http://www.scan.co.uk/products/amd-...-38ghz-amd-radeon-hd-7660d-800mhz-100w-retail <---- £96
    http://www.scan.co.uk/products/msi-...gb-s-raid-pcie-20-(x16)-d-sub-dvi-d-micro-atx <------- £54 and a ton of sata 3 (and has usb 3)
    http://www.scan.co.uk/products/8gb-...0(1866)-non-ecc-unbuffered-9-10-9-27-xmp-150v <----- £65 8GB of cas 9 , 1866 MHz ddr3
    that's IF you don't want to keep your GTX560Ti.
    otherwise keep it and look at an AMD FX 6300 , board and ram
