Modding Project: WorldMap
Discussion in 'Modding' started by Pfaffen, 18 Mar 2007.
  1. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    This is my first Case Mod.
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Welcome to bit-tech; in order to get your picture to display properly, you'll have to host it somewhere like imageshack and then paste the code they give you into your post :)
  3. Pfaffen
    18 Mar 2007
    Thanks
    Thanks... Also first time posting the results.
    :confused:
  4. Mr-IK
    Mr-IK Minimodder
    12 Mar 2007
    Looks pretty nice :)
    Would fit perfectly into one of those old english looking offices :)
  5. ElThomsono
    18 Mar 2005
    Yeah, that's pretty cool ;)
    Great design too :thumb:
  6. Pfaffen
    18 Mar 2007
    Close up
    Here is a close up of the front of the case. The DVD tray is concealed behind the map. The button for the DVD is walnut (I left it unfinished) The frame for the case is mahogany and the map is glued to .25" plexiglass.
    The brass screws (3 per HD) hold the two 250GB SATA drives. I re-enforced the plexi with a smaller plate of plexi. So now the two droves "float" in the case. Actually, they are only affixed on one side.
    Here is the case before I glued the map to the plexi.
  7. OremLK
    OremLK What's a Dremel?
    2 Mar 2007
    That's really cool. I like the wooden frame. Did you put it together yourself?
  8. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    Your design looks strangely familiar :D . Good job though.
  9. Pfaffen
    18 Mar 2007
    Strangely familiar
    greensabbath,
    Your case was my inspiration. I was very impressed with yours and like alot of the features yours offered.
  10. Pfaffen
    18 Mar 2007
    Yes, I started about 6 weeks ago.
  11. Pfaffen
    18 Mar 2007
    Another shot
  12. Pfaffen
    18 Mar 2007
    Original pieces
    Here are the original pieces.
    [​IMG][​IMG]
    And some more closeups...
  13. Guest-23315
    Guest-23315 Guest
    That looks nice indeed.
  14. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    I was going to say the same. Nice work though :)
  15. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    sadly you didnt post it as a log.. i'd hand out a few stars.
  16. Pfaffen
    18 Mar 2007
    Not posting to the work log
    I had originally intented on posting this on the work log, but after I read the rules, I figured it would be better served in the finished work sections.
    Also, I'm looking for a place to host all the pictures. I have almost 200 picts of the projects. From the very first to the last.
    Anyone know where to host that many pictures. I used image shack at first but seem to be limited on the number of pics there.
  17. Pfaffen
    18 Mar 2007
    Close-ups
    Here are some closeups.
    This is the DVD Drive and the eject button.
    This is the front 120mm cooling fan vent.
    This is the back with the two 80mm fans.
    The case has (1) 120mm fan in the front, (2) 80mm fans in the back, (1) 120mm fan in the PSU that vents to the bottom and the CPU fan. Keeps everying nice and cool. Then again the AMD 64X2 4600+ doesn't run that hot to begin with, but the two SATA drives are kept comfortable.
  18. Pfaffen
    18 Mar 2007
    Moved pictures to photobucket.
  19. Pfaffen
    18 Mar 2007
    90 days, and still running.
    On to my next project: Case Mod Fibonacci
  20. wbdog206
    wbdog206 not me
    15 Jan 2007
    wow that is cool,the map idea is great.
