Expanding a H60 to fit an EK 750Ti Waterblock
Discussion in 'Watercooling' started by Impatience, 9 May 2014.
  1. Impatience
    Impatience Minimodder
    6 Apr 2014
    As the title says really.. I've learnt that EK is making a 750Ti waterblock (Finally a single slot card! :clap:) and I'd like to expand the H60's Loop to include it. Is that possible? (I know I'd need adaptors etc) The cooling should be enough.. (750Ti and a i3-4130, so it's not power hungry!) I'd rather not have to spend more on a complete new cooling loop since I've only recently bought the H60..
  2. Impatience
    6 Apr 2014
    Dome some research on this. Apparently you can't do it because the pump isn't powerful enough, and I'd need to add a res also to fill up the loop more.
    Does anyone know if you can use the radiators from the Corsair AIO's in a standard loop? I've seen you can get 200mm radiators, and that with the AIO's 120mm is supposedly enough to passively cool an i3 and a 750Ti..
  3. Impatience
    6 Apr 2014
    Maybe not.. Different metals! :duh:
  4. The_Crapman
    5 Dec 2011
    Check my sig for a link to where i modified an antec khuler 620 to include the Northbridge block my mobo had. I recon it's probably be enough considering neither the cpu or gpu are power hungry beasts.
  5. jinq-sea
    15 Oct 2012
    There was an article in a recent Custom PC about modding Corsair AIO coolers - worth a look. I think it was last month's?
  6. Impatience
    6 Apr 2014
    Ooh.. Where would I find that, jinq?
