Cooling Sealed Watercooler Lifespan
Discussion in 'Hardware' started by lilgoth89, 22 Feb 2017.
  1. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    basically i have pulled a sealed watercooler ( H70 ) from my backup rig ( that hasnt been turned on in a fair while ) and i wondered if it is still good ?
    the unit powers on ( as far as i can tell, and the sound of water flushing can be heard ( as well as sloshing when moving the rad ) but its running outside a system currently for testing and hasnt seen any 'heat' thus far
    i heard that the fluid can separate in these units and ruin the pump somewhere, or that it evaporates through the tubes and thus the lifespan is limited so i figured id hand the question over to you folks
  2. The_Crapman
    5 Dec 2011
    The evaporation is negligible, my brother has an original h50 still running in a rig, must be getting on for 10 years old. As long as there's not significant noise coming from the pump I'm sure it will be fine.
  3. Vault-Tec
    30 Aug 2015
    I would imagine if anything separates it would mix up again when you start the cooler?
    What's the worst that could happen? your CPU overheats and the rig shuts itself down.
    I've never seen one of those coolers (it's the bendy straw tube one yeah?) leak.
  4. Jimmy6
    Jimmy6 What's a Dremel?
    19 Jun 2011
    So if sealed coolers last so long, why are you meant to bleed custom loops every 6-12 months?
  5. Vault-Tec
    30 Aug 2015
    Because custom loops don't use antifreeze mix.
    Jimmy6 likes this.
  6. Jimmy6
    19 Jun 2011
    Didn't know that!
  7. TheMadDutchDude
    23 Aug 2013
    Also, who doesn't take their PC apart in a year to clean it and/or change and part?? Come on, we are enthusiasts. ;)
  8. wolfticket
    19 Apr 2008
    I would guess it's because sealed watercoolers are protected from containments during production and then permanently hermetically sealed, whereas custom loops aren't.
