Case Mod - In Progress [颖]Project conceptmod - Acrylic tubing!
Discussion in 'Project Logs' started by ying, 7 Apr 2012.
  1. ying
    ying What's a Dremel?
    26 Aug 2011
    Hello everyone! :)
    I'm a long time reader but this is my second post here. My old project was dreampc and I didn't like it at all for some personal reasons and now I'm here, working in a new project but in the same case, corsair obsidian 800D. In this forum there are a lot of real artists so hope you like my project :D
    Sponsors:
    I would like to give a big thanks to Ricardo from Coldzero (www.coldzero.eu):
    Coldzero will cut with laser all my designs and to ProfesionalReview (http://profesionalreview.com):
    [​IMG][/URL]
    A spanish review web and who will give to me some surprise items :D
    And Corsair:
    Hardware:
    -Intel i7 920 D0 @ 4.2 GHz
    -Asus Rampage III Extreme
    -2 way SLI: Point Of View GTX 480 + EVGA GTX 480
    -Corsair Dominator Airflow II 6Gb (3x2048) PC3-15000(1866Mhz) - CL9
    -Corsair HX850
    -Seagate Barracuda 500GB
    It's not really new hardware but I'm poor and can't purchase new gen. hardware and still saving money for the SSD :D.
    Watercooling stuff:
    -Ek supreme HF Full nickel + Easy Mount system (black)
    -Aquacomputer Aquagrafx gtx 480 nickel:
    -Ek-FB RE3 - Acetal+Nickel
    -Black Ice SR1 480
    -Black Ice SR1 240
    -Swiftech mcp 655 (x2) + Ek D5 dual top (single loop) White Acetal
    -Fatboy fittings of 13 mm OD
    -TFC Connector Fill/Drain Port
    -Scythe gentle typhoon AP-15 (1850 rpm) (x4)
    -Scythe gentle typhoon 3000rpm (x2)
    -Ek RAM Dominator EN nickel + acrylic.
    -4x120mm Fan Radiator Shroud, Black
    Purpose:
    Reinvent myself! :)
    Design:
    As like the old project, I work with CAD software, mainly Autocad and a solidworks and about this last one, I know just a little bit of how to use it, but I know the enough for doing what I need :D.
    This time, the design is going to be simple, combining the matte-black color (mainly) plus the blue color and a little of white in some little details!
    An example of design type about what i'm going to do:
    The main pieces are:
    Motherboard Tray Plate:
    This plate is a plate that covers the free zone near the motherboard and this is the design:
    And I want to highlight this little plates:
    Why alot of holes? because in each hole I will pass one sleeved cable so the final result of all the cables passed is like a spider structure (very aesthetic in my mind, hope I will get a good result!). In every hole there are a little "ring" wich will be illuminated so the contrast with the black cable will be awesome! This plates correspond to the 24 pins plate and the GPU power cable plates.
    Custom backplate:
    Nowadays there are a lot of mod with Waterblocks + backplate combination build but I wanted to try to be different to other people so decided to design my own backplate:
    It's simple, full matte-black plate + the gpu model letters. In real it's a double backplate, one black and one blue. All the blue parts, like the mb tray plate will be illuminated with SMD leds directly connected to the GPU fan connector ;)!
    Last week I found a really good offer of a gtx 480 for 200€, so I decided to buy one and this is it:
    wich will be configured to SLI with my old POV GTX 480 with aquacomputer waterblock:
    So there will be 2 custom backplates for each GPU and the two backplates illuminated too.
    By now, that's all the pieces that I have already done! for the next days I will post the custom midplate and probably the full faceplate.
    All this pieces are designed by my own but will be made with laser cutting tech.
  2. ying
    26 Aug 2011
    More renders:
  3. ying
    26 Aug 2011
    Hi! I have been very busy this days and had not time to start modding the case but I have got a lot of new cad designs. Today I have made a video showing the process for design my pieces, in this case a fan grill:
    Recommend to see the video in 1080P
  4. ying
    26 Aug 2011
    Pictures of the first cutted pieces: the two backplates for my two gtx 480 in SLI config. The backplates are made specially for the aquacomputer gtx 480 waterblock:
    The backplates:
  5. Cheapskate
    13 May 2007
    Looks good.:D Are the letters sitting in a milled inset? It's hard to tell.
  6. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Looks like it. That's an easier way of doing too as you don't have to worry about dealing with the character's counters as everything is an open path.
    Looks nice!
  7. ying
    26 Aug 2011
    The backplate in action:
    SMD leds:
    A backplate specially made for the Asus Rampage III Extreme motherboard:
    And my next step:
    ROG logo with blue leds :D!
  8. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    :rock: thats one puuuurdy backplate!!!
  9. ying
    26 Aug 2011
    Custom 120 / 140 grill for obsidian 800D + prolimatech 140 blue fan:
    And now just arrived the 5 meters of SMD leds purchased from ebay:
    This leds are more bright than old ones, are so bright that I must connect them to a rehobus to avoid eye damage every time I look to the pc :cooldude: .
    And this is how it looks installed and working in the backplate:
    And a "bonus" picture of my new mouse R.A.T. 9:
  10. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    That backplate looks amazing! You really did some quick work on it! Was it laser cut?
    Great mod so far!
  11. James'Mods
    James'Mods Mad Man Modder
    5 Mar 2012
    Good to see you on here ying! Really amazing work on the backplate and fan grill. I already subscribed to your thread over at XS.
  12. James'Mods
    5 Mar 2012
    It's all laser cut. :cooldude:
  13. ying
    26 Aug 2011
    Hi!
    It's good to see you here too :D
    Hope you enjoy in my next updates. My next step is to customize a CPU waterblock :rock: and to end the midplate.
  14. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    i love those custombuilds :D,
  15. ying
    26 Aug 2011
    The LCD connected to the PC:
    YEHBABY likes this.
  16. Halchart
    Halchart What's a Dremel?
    26 Jul 2011
    I just received one of those LCD displays the other day myself. I really like it and got one new really cheap. I really like your build so far keep it up.:thumb:
  17. ying
    26 Aug 2011
    Yeah! they aren't expensive and can be full customized :D
    By now I don't know how to do for showing the CPU core temps in the LCD, I know that there's a speedfan plugin but I can't make it work :S
    you know how to?
  18. Halchart
    26 Jul 2011
  19. Squigly
    20 May 2012
    Did you ever get around to doing this?? I'm thinking of doing the same to mine
  20. ying
    26 Aug 2011
    No, but I think that it's easy to change the led.
    I will done it in the near future, when getting all the new watercooling stuff.
