Windows COD:WaW beta problems (solved)
Discussion in 'Gaming' started by kenco_uk, 29 Oct 2008.
  1. kenco_uk
    28 Nov 2003
    Does the beta work on Vista x64?
    I downloaded it earlier and have installed it now and upon launching the game, the screen/display goes really skewiff (there's no way I'd get a screenshot of it) and I end up having to power off the computer.
    After a reboot, I get the option to start the game in safe mode and all I get is a '..stopped working' error window.
    I have 178.13 NVidia drivers and the rig in my sig. Seemed to install okay.
    edit: keir's post solved the issue I was having.
    Playback settings, speakers, properties, advanced.. changed the audio setting to 24bit, 44100. Works a treat now.
  2. UrbanMarine
    UrbanMarine Government Prostitute
    7 Aug 2008
    I haven't had any problems like that but the game does crash if I alt-tab out.
  3. kenco_uk
    28 Nov 2003
    Ah well, I'll have to have a go with it on my lappy.
  4. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
  5. MixWizard
    MixWizard Minimodder
    16 Jan 2007
    Mine crashes when i attempt to adjust GFX settings
  6. kenco_uk
    28 Nov 2003
    I put the 180.43 beta driver on, still the same problem :(
    Other games work fine.
  7. Fredrics
    Fredrics Hmm...
    31 Dec 2007
    It is working perfectly on my vista x64 so that is not the problem. Maybe try re-downloading it, you may of got a corrupted file.
  8. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    i see what they did there.
  9. kenco_uk
    28 Nov 2003
    Aye, am doing that now.
    WaW - giving everyone a Wossy complex.
  10. Jipa
    5 Feb 2004
    Anyone know where I could get a beta key? I'd LOVE to try the WaW out as I've spent disgustingly many hours playing all the earlier CoDs...
  11. 5hadow
    5hadow What's a Dremel?
    24 Aug 2008
  12. Slepnyrl
    Slepnyrl What's a Dremel?
    6 Jun 2008
    Yeah, I've been waiting a few days for them to send me my beta key already...I've played all the COD games on the pc and loved every one of them (especially on Tactical Realism mods server). I don't know how CodWaW will hold up though.
    Any ideas on how much time we need to wait?
  13. keir
    keir S p i t F i r e
    5 Oct 2003
    I had an issue where the game wouldn't even launch.
    Some kind of initilization error.
    It works now after changing the sound card to run at 44K
  14. kenco_uk
    28 Nov 2003
    keir - you the man now dog! Changed the audio setting and it works perfectly!
    I'd never have known to do that.
  15. Jipa
    5 Feb 2004
    I keep disconnecting from servers and it says "G_spawn: No free entities". What the hell does this mean?
  16. slugs
    slugs Minimodder
    4 Dec 2001
    G_spawn: No free entities is because they are running servers with more than 32 users.
    its quite fun to have loads of people on i found. but you get into a spawn die spawn die look sometimes
  17. heir flick
    heir flick Minimodder
    2 Feb 2007
    just gave it a go and like it alot, top notch graphics and plays just the same as cod 4 but with tanks
  18. keir
    5 Oct 2003
    Glad it worked for you. :)
