Scratch Build – In Progress 1 of 3 Project :: DIY Aluminum CNC (Finish Lastest update 04/09/2013)
Discussion in 'Project Logs' started by iD2, 11 Jul 2013.
  1. iD2
    iD2 Minimodder
    25 Mar 2012
    Welcome!!!​
    See all project at my blog here :: iD2CNC.wordpress.com
    Project No. :: 1 ,(1 of 3)
    Project Name :: iD2CNC v.2.0
    Project Description :: This project i will start to make Aluminum CNC and use this CNC to do my PC Acrylic Case ,why i need to make new CNC because actually i have my own CNC but already sold it ,so that that why i need to make new one.
    Project design ::
    Specification ::
    X-Axis :: Working area 700mm
    Y-Axis :: Working area 520mm
    Z-Axis :: Working area 120mm
    X-Axis :: Using SBR Rail ,Dual ballscrew and drive
    Y-Axis :: Using SBR Rail
    Z-Axis :: Using Linear guide
    Spindle :: 1.5KW Water Cooled ER16 + Inverter
    Safety :: All axis have limit switch
    Auto Zero Tool :: Have auto zero tool
    Overall dimension:: 1000x860mmx550mm
    Incoming 2nd , 3rd project ::
    Project No. :: 2 ,(2 of 3)
    Project Name :: iD2CNCB v.1.0
    Project Description :: This project i will go to make and CNC Controller enclosure actually it not much detail , it will simple and easy to do it.
    Project design :: N/A
    Project No. :: 3 ,(3 of 3)
    Project Name :: [GT] Carbide Series
    Project Concept :: It not just system , it your Style
    Project Description :: This project i will go to an acrylic PC case. I design it to transparent both side and font panel to show what's your style inside or how your style inside.
    Project design ::
    [​IMG] [​IMG] [​IMG]
    6 Colors to compatible with your component
    2 version release , Right hand style and Left hand style
    Specification ::
    Model :: [GT] Carbide Series
    Dimension :: 620mm x 540mm x 260mm (W x H x D)
    Material :: Acrylic
    Color :: 6 colors
    Side Panel :: Transparent Side Panel
    DVD 5.25″ bay :: 1
    HDD 3.5″ bay :: 2
    HDD 2.5″ bay :: 7 (3x for Show your SSD or HDD , 4x for standard use)
    Motherboard :: ATX or mATX
    Case Type :: Full Tower chassis
    System Fan (Font) :: N/A
    System Fan (Rear) :: 1x 120mm
    System Fan (Top) :: 4x 120mm
    System Fan (HDD) :: 2x 120mm
    System Fan (Rear buttom) :: 2x 120mm
    Features ::
    - 2 version release , Right hand style and Left hand style
    - Support 4x120 radiator
    - Transparent side panel (show your style here)
    - Support 6 colors to compatible to components inside
    - Support custom name on font ( see it at "[GT] Carbide Series")
    All Project by ::
    Hope you like it.
    PS. I'm not good in English , If i make you confuse please feel free to ask me.
  2. iD2
    iD2 Minimodder
    25 Mar 2012
    Just went to shopping for a couple week ago.
    and aluminum profile and aluminum accessories just arrive today
  3. Azariel
    Azariel Minimodder
    23 Oct 2008
    Great first post! I'm already jealous before you really started building!
    Mind if I ask why you sold the first one?
  4. Asouter
    Asouter --------
    18 Jan 2012
    Looks pretty cool, I'm looking forward to seeing how the CNC comes together.
    Any links or tipos on making one of these, you said it's very easy but it doesn't look like it
  5. iD2
    iD2 Minimodder
    25 Mar 2012
    :D First one i sold it because i need budget to build Plasma CNC 4'x4' or 4'x8' but after sold it i realize that i not ready to build Plasma CNC.
    Thank you, Like you said it not easy but for me i drawing every component with actual size using Google SketchUp and then i design it , how it connecting together , how to make it rigid , how many component need , etc..
    For how i do it you can see my old work log here DIY CNC by iD2
    Note :: Tons of picture and my English not good but only an images will make you understand what i'm doing.
  6. iD2
    iD2 Minimodder
    25 Mar 2012
    Update my tools for build my CNC
    and other important tool was power drill. I'll take picture it soon.
  7. iD2
    iD2 Minimodder
    25 Mar 2012
    Update just change my mind last minute before drill and assembly it. For Y-Axis i change my design from using aluminum profile 40x40, 40x80mm to 60x60 , 60x60mm it will make much more rigid and no need to drill and tap for connecting rod rail to aluminum profile. Why i'm not use 60x60mm for the first time becase i'm try to make this machine rigid and cheap by reduce unnecessary parts. OK no more talking just see. :D
    it will look not change because it same height 120mm
  8. iD2
    iD2 Minimodder
    25 Mar 2012
    Just got Water cooled spindle + Inverter + Spindle clamp. So today i do wiring and add Potentiometer to Inverter and then test them to make sure everything work fine and correct wiring.
    Item arrive ::
    Unpack the package
    Start wiring ::
    Note :: For single phase power use “R” and “T” but for Three phase power use “R” and “S” , or “S” and “T” , both will work fine.
    After finish wiring then test run ::
    Note :: Before start run it VFD need to parameter setting.
    - PD005 = 400 (Hz)
    - PD004 = 400 (hz)
    - PD003 = 400 (hz)
    - PD008 = 220 (220volt)
    - PD072 = 400 (hz)
    - PD144 = 3000
    This parameter need to set up before start run spindle. Other parameter see document.
    After test , It work correctly and everything good so next i need to add potentionmeter to font panel of inverter , it already have socket for putting potentionmeter into it.
    Done !!! lol​
    Video test here ::
    PS. I can not insert Youtube link , it show big white box ??
  9. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I'll be keeping a watch on this. one of my long term wants is to build a small home cnc.
    Think you may have linked the video wrong - I took the url out of the page source to watch it but I don't get anything on the actual forum page, just a big white box
  10. Pranja
    Pranja Blackwolf
    18 Dec 2011
    Watercooled spindle-nice. :)
  11. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you, hope you enjoy my work log.
    For youtube link i still confuse how it didn't work.
    :D
  12. dynamis_dk
    23 Nov 2005
    I think if you edit the post and just put the code bit from the end of the full YouTube URL within the tags I should work
  13. iD2
    iD2 Minimodder
    25 Mar 2012
    Thank you. I'm try but not sure why it not work.
    And tomorrow i'll get aluminum sheet and rod rail , support rail , ballscrew etc... will coming inf few day and other Electronic will coming maybe next week or next week.
  14. iD2
    iD2 Minimodder
    25 Mar 2012
    Just got an aluminum sheet
  15. Azariel
    Azariel Minimodder
    23 Oct 2008
    Sheet he calls that...:worried: Thats a slab my man! You could hit someone to death with that :p
    Anyway, I am quite curious about the price of such a setup...I mean I guess the total goes towards the €5-10k or so?
    If so, do you sell parts you make on it or just as a somewhat expensive hobby?
    Don't get me wrong, I'm not judging! I think we all have the tendency to spend money on things most of our fellow humans would never even consider :dremel:
  16. iD2
    iD2 Minimodder
    25 Mar 2012
    :D What it call for aluminum like that? (Sorry i'm not good in English).
    Cost of this machine total not over 2,000$ for everything and i can make it cheaper by replace table top to use wood if i do that total about 1,800$-1,850$. Now everything was order and i use aluminum profile for my table top but my cost now 1,950$
    For this machine i'm build it for do my hobby and will use it to get some money back.
  17. xXSebaSXx
    xXSebaSXx Minimodder
    21 Aug 2010
    Don't we all?
    You'd be surprised as to how "inexpensive" DYI CNCs can get. Search for 80-20 DYI CNC and marvel at the thousands of different options available.
    PS: 80-20 is but one brand of extruded aluminum profiles. There are plenty others out there and, like with everything, for every brand there is an "enthusiast" community. :)
    I think he's just messing with you man... We usually think of metal sheet as something in the 1mm to 2mm thickness... Beyond that; we think of them as weapons. :)
    As for the DYI CNC. Did you design it yourself? Or did you get the design, parts list from one of the many DYI CNC sites out there? I'm planning on putting one together some time this year (need to buy a lathe first) and the design you have seems to hit every one of my needs...
  18. iD2
    iD2 Minimodder
    25 Mar 2012
    For this design i design by myself and drawing parts by myself to make sure i got a precision model before putting them together , i drawing parts from datasheet that i get from official site or from supplier.
    And this design you see it 9th revise (Only major change that i count if for minor change i think i revise it over than 30 time before get this final design)
    Note:: For part you can get from official site they will have CAD drawing with precision model but i use SketchUp , it faster for me if i drawing it by myself.
  19. Evenge
    Evenge Minimodder
    16 Sep 2006
    I have a feeling this is going to be awesome project! Btw love how you matched the SSD drives by brand to your color options. ;)
  20. Cheapskate
    13 May 2007
    Awesome.
    For the people interested in doing something similar, please add as many brand names, model numbers, and links as possible.
    -On your design: If you put the Y axis screws on the side of the table, you get more clearance.:D
