Modding Hall Of Fame - Spra-Mod - FINISH 24 Mai 2015
Discussion in 'Modding' started by Spranox, 7 Mar 2015.
  1. Spranox
    Spranox What's a Dremel?
    6 Mar 2015
    Hello everyone
    I present non mod Who Will remain in the simplicity and sobriety while being white Efficient .
    In CE mod, non formwork is unoriginal With Scheduled layout and coat revisited That I could have done until now ...
    A watercooling been redesigned , I PAST flexible to rigid acrylic pay was unveiled BE ! When the formwork to Him serums made ​​of aluminum
    Color level, I 'm going on matte shades , Clear lacquer UN mat For The All That Either under protection by keeping the matte appearance.
    A slight redesign of serums case review in order to guarantee the right of Conduct project.
    The sera aussi duct section
    Photos before and after and pendant will animate this Small Worklog .
    Config
    I7-3770K
    Maximus V Formula
    GTX980HOF
    16 Giga Corsair Dominator 1600Mhz Cas9
    Corsair HX850
    SSD Samsung Evo 250 Go
    Haf-X
    Here is a version of the X - Haf revisited by me , Coolermaster would struggle to recognize I think although it still remains some things of Haf -X émoticône smile
    Here is my vision of modding , class, clean , and just stylish! I hope not to be too modest.
    Be kind with your comments this is my first mod !!!!
    17 Pictures is off to an idea of this project émoticône smile enjoy and share in a max please émoticône smile
    Thank you for following me , probably the next for new adventures in the world of modding .
    Sp- Mod.
    Small update
    A new facade and projected original facade of Haf -X trash
    Also note , the current lighting and the planned test will fill shadows....
    to be continued...
  2. GoodBytes
    20 Jan 2007
    Those pictures.... looks like you worked in marketing :)
    Truly awesome. Shows your love of you project. I hope it genuinely looks as good in real life as those shots :)
  3. Spranox
    6 Mar 2015
    I am a beginner in photography , I applied a lot because I love what I do.
    In reality it's just as beautiful! it is perfectly well represented
    Thank you for your comment,
    I apologize for my English , I use a translator :thumb:
  4. GoodBytes
    20 Jan 2007
    Truly awesome!
    I am very impressed! :)
  5. Spranox
    6 Mar 2015
    Thank you :thumb:
    Small working day...
  6. GoodBytes
    20 Jan 2007
    I really can't wait to see the finish product. :D
    I have a challenge for you when you get there. I don't know anyone that does this. It is minor, but attention to detail. Only Apple and Microsoft, to my knowledge, does this.
    The USB port at the front (or side, or top of your case, where ever they may end up being, if any), in most computer cases, monitors, laptops, and so on, you see the USB cut is done too big, where you see the casing of USB port.
    I challenge you, if you can, not only make the cut for teh USB port exact, where you dont' see the ugly casing, but also dye the metal of the USB port.
    in other words:
    Don't have this:
    But have this:
    Notice how the USB 3.0 port is near invisible. Now i know you can't do anything with the plastic tab at the inside, and probably it will need to remain blue. but you notice that because the hold is cut to perfection, and the USB casing is also black, its not visible like a soar thumb.
  7. Spranox
    6 Mar 2015
    Small test on alu fall, I wanted to see the resistance with such fine cuts on 1mm thick
    meets the grounds of the facade can take shape.
    Reminder is falling ! small piece that have nothing to do with the façade will be set up !
  8. Spranox
    6 Mar 2015
    Then for eight aujourd facade, cutting over, well I admit that I was eager to share with you my progress , I still have to make a repair key - double component & sanding.
    Aprésent I have to focus on a technical aspect, which is to isolate the red color of the white
  9. Spranox
    6 Mar 2015
    Petite avancée, me reste plus qu'a faire les ouvertures sur le dessus du boitier que je ferais sans doute demain.
    début de la mise en couleur, j'ai profiter de la pluie et l'absence de vent pour en profiter .....à suivre....
    Photo Peinture noir - premiere couche !
  10. GoodBytes
    20 Jan 2007
    Wow! Super beau!
    J'ai hate de voir la fin du projet! :D
  11. Spranox
    6 Mar 2015
    Alors avancement couleur :)
    Pas encore fini ! entre chaque couche, un coup de papier de verre pour retirer les éventuelles irrégularités car nous ne sommes jamais à l’abri d'une poussière même par temps de pluie :)
    sur la façade j'ai encore des zones de transparence, encore 2 couches pour la façade + vernis incolore Mate :)
  12. wolfticket
    19 Apr 2008
    Ooh er missus. The style of the photography makes it look kinda illicit. The thread needs NSFW tags :)
    Beautiful work.
  13. guitarhero23
    guitarhero23 What's a Dremel?
    27 Mar 2015
    The HOF card sare sexy
  14. Spranox
    6 Mar 2015
    So for now the time to view this tape that **** in Belgium , I decided to make a Rigid Tubing simulation,
    I also drilled a hole in the top of the form which will place the tank , color painted finish on the bottom plate of the Pc .
  15. Spranox
    6 Mar 2015
    I want to say tonight I 'm not very picture! I did stereotype but it will not ... bad light , so I have retained very few pictures of my work.
    I put the finishing touches on all layers of the white pieces including the facade I had to do it again, and now all at my convenience !
    I also painted brackets to make the edges of the cleaner case because at the beginning of how I removed the reinforcements that allow to keep the side door , and for that I do not want door apart at the back I ' I removed them , I find that the result is there!
  16. Spranox
    6 Mar 2015
    I made pictures Black & White Photo Color for those who want to change
    I love this kitchen table a good LED lamp below and here's a nice picture work area
    Small assembly phase following happens be patient ...
    even in the assembly I take my time
    Couleur
  17. Spranox
    6 Mar 2015
    Today mounting the shuttering formwork suspended + down with integration of bar plexi !! Not for now Suspense ignition
  18. Spranox
    6 Mar 2015
    Thanks :) Subbed for shore ?? i do not understand sorry
  19. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Amazing work with logo.
    This project should be moved to the porject-log section ....
  20. Spranox
    6 Mar 2015
    Thank you for your appreciation of this mod :)
    I give my heart for this mod !
