Modding The Tiger
Discussion in 'Modding' started by Phenom, 27 Mar 2015.
  1. Phenom
    Phenom What's a Dremel?
    26 Mar 2015
    Hello world,
    I come to you to present my new project named Tiger
    First objectif :
    Having this configuration for DreamHack 2015 in the city of Tours in the month of May
    Configuration :
    - Boitier : Bitfenix Shinobi noir sans vitre
    - CPU : Intel Core i7 4790k
    - Carte Mere : Gigabyte GA-Z97-OC "
    - RAM : 16gb Avexir Blitz 1.1
    - Carte Graphique : Gigabyte GTX 770 OC
    - Alimentation : Corsair RM 750
    - HDD : 2 SSD crucial 128Gb
    - Refroidissement : CoolForce
    Color of the theme
    - Orange
    - White
    - Black
    So I started working out on white sheets to already take the hand with the airbrush and also have a glimpse of what it will give .
    Here are my first attempts at painting :
    - 1st test :
    - 2nd test :
    - Both for choice :
    - The future cutting the left side which will be glazed by the following :
    - Paint :
    - My guardian for cutting ..... My little tiger " Moumoun " like " moomoon
    - Cutting :
    - Small passage primer :
    - The choice of my fans for this mod : Cougar Vortex 120 and 140mm
    - My first cuts:
    We do not forget the glasses with the dremel !!!!
    I just received the psu I ordered and also the cable kit I won on the Facebook page CableMod a kit Orange / Black visible in a previous post .
    walk a little on the mod I removed everything inside " the support of the motherboard, HDD cage and 5-inch bay " , I gained some space , I finished making the system opening scratched facade , it remains for me to sand the inside to remove the rail system. This leaves me sticking this one on my opening system , do the cutting of plexi to scratch and then we will attack a little paint .
    I have yet to realize the plans on Solidworks for the plate which will host the motherboard and also the host of the two tanks I bought .
    I also bought two tanks, one EK radiator and my sweetie with a complimentary EK pump so I advance on the project that will be a reminder for OP DreamHack .
    I finished this weekend painting TEST an SSD , I'm just finishing the plans in 3D motherboard support , I also finished removing the rim of the scratched face I can fix it on the opening system , there will me more than to buy powerful magnets to create the binding.
    Before :
    After modding :
    That all for the moment. see you guys
    Facebook :
    https://www.facebook.com/phenomdesignphotography
  2. Impatience
    Impatience Minimodder
    6 Apr 2014
    This is Phenomenal work there! (See what I did there?) :hehe: Seriously though, your painting and marking skills are on point! :clap: Can't wait to see the rest of this!
  3. Phenom
    26 Mar 2015
    Some news !!!
    for first thanks a lot for your comment
    i received some pieces :
    first mounting to see :
    I painted the fan covers and tank support and primer set many thing tomorrow I will still have a job in painting.
    I also finished fixing both SSD and pump.
    I place an order for two sata cable 15 cm
    It remains for me to wait for the fittings and tubing normally and tomorrow I get a sample of a piece I had printed in 3D with the 3D printer taf .
    I need to do some adjustement and go print 4 pieces :
    1 TIGER
    1 EDITION
    2 with i line like the support of tanks.
    That all guys see you later.
  4. Phenom
    26 Mar 2015
  5. Phenom
    26 Mar 2015
    Here the final photo of the mod Tiger
    Share and like on my facebook page
    Phenom Design & Photography
    Thanks To my Sponsor :
    Intel France
    Avexir Memory
    Gigabyte France
    CableMod
    CoolForce
    Bitfenix
    See you soon.
