Scratch Build – In Progress F(L)AT by FAT (rhymes ;) )
Discussion in 'Project Logs' started by FAT, 23 May 2016.
  1. FAT
    FAT What's a Dremel?
    19 Mar 2013
    Hi Guys!
    It has been a bit quiet lately, but that doesn’t mean I’ve been sitting around entertaining Pixel (.. ok a bit true ;))
    This is a build made for MSI, they asked to make 3 demo systems to sent to reviewers and press in Europe.
    There were a few conditions to this build;
    All the best features of the hardware had to show (duhuu)
    It had to be solid and sturdy so it could be send to lots of different locations.
    New hardware that hasn’t even been invented yet has to fit in there ;) !
    The first one was the prototype and this one was displayed at a event in the Netherlands called Firstlook.
    Here are the renders of the scratch build!
    Very easily said, it is a flat surface where you can install the motherboard and the GPU. In the stand at the back of the case we will build the power supply and SSD.
    2 things are very important, a good PCI-express cable and a modded AIO cooler!
    Highflow.nl has the perfect PCI-expresscables from Li Heat. these calls run stable on 3.0 and are available till 35cm and nicely covered in black fabric. Looks perfect!
    This is where it all begins, steel steel and more steel ;)!
    Drawing everything on
    &…..cutting!
    Cutting angles so all the parts will fit together nicely in the end.
    Now, puzzle everything together ;)!
    This will be a part of the stand at the back of the case which will hold the power supply.
    In the middle there is extra steel reinforcements on which we can attach the foot of the case.
    The cable has to go through the frame so there will be a rectangular hole in the profile so it will fit through nicely!
    The On/Off switch will be placed there
    Checking the angles!
    Ready to weld everything together!
    Normally we solder stuff together in stead on welding. Welding something together is no problem, but I doubt that it will win in a ‘beautiful-welds-contest' ;) ! Luckily it will look nice afterwards.
  2. arduum
    arduum Minimodder
    10 Mar 2015
    o, fat!:clap:
  3. FAT
    19 Mar 2013
    Yes, we're back ;) :dremel:
    Ok, this is how the prototype was build. We welded the frame with brass welding rod and a propane/oxygen torch but we quickly decided to switch to simple electrode welding. This worked out a lot easier and quicker!
    After the prototype we also adjusted the design of the frame so it became lighter and more sturdy!
    This is the outer frame welded and sanded, already looking good (if I say so myself ;) )
    Tenzin did the drawing for the backplate in illustrator and lasercut it out of wood.
    Fits like a puzzel :D!
    Made the angles so the profile fits in the frame nicely. There will be 2 horizontal and one vertical beam in the frame to attach the stand/foot to.
    The stand at the back looks like this and will hold the power supply!
    Everything put together :D! Tadaa
    In the last update there was a hole in the profile of the frame where the riser cable was supposed to go through.
    This is the prototype and with this one we had to cut it out after welding the frame together ;) !!
    The Vandal switches with a lighted white ring around it
    The beautiful black 35cm riser cables from highflow.nl
    The RGB controller from Aquacomputer with bluetooth!
    The backpanel was a lot of work to draw. The radiator and fans have to blow the air through and the motherboard will be attached to it. There will be a cut out to easily install the CPU Cooler.
    The result in the next update :D !
  4. amagriva
    amagriva Minimodder
    13 Jun 2009
    Wow! Very nice...
    Thumbs up for your skills as a builder with different materials and tecniques:thumb:
  5. Hukkel
    Hukkel James' minion
    20 Dec 2012
    You go Tenzin and Femke!
  6. Cheapskate
    13 May 2007
    Beefy! If it's a trade show piece it might crush some bumpkin.:lol:
  7. FAT
    19 Mar 2013
    Thanks Amagriva! I have a lot of goldsmitthing tool that come in handy doing this kind of work, so that helps a lot! (and a workshop that I don't have to clean up as often as the house ;) )!
    WOohoooo :D ! Thanks Tim!:clap:
    Hahaha Yes it is very study :thumb: !
    Ok,
    After welding trying to fit everything together again!
    The on/off switch :)
    Ofcourse we tried to testfit every component, so that you have a good idea of the size of the frame in total.
    On the right of the motherboard there will be a 240 radiator and below the GPU. The powesupply and the SSD will be placed in the foot at the back!
    The frame, sanded and ready for painting.
    The corners of the frame are made of POM (acetal) a very tough and hard kind of plastic which will not break
    They will protect the frame from blows and other things during transportation.
    In the next update I will add the pictures of making these corner pieces!
    Drilling is relatively easy in this material. These holes are for some customized nuts. The nuts are customized on a lathe so that they can be easily pressed in the corner pieces.
    In the corner pieces we made some thread to hold the bolts in place. The thread will make sure that the bolts don’t have to be glued in but are simply clamped by the thread.
    Cut out a bit of material to make it fit to the frame perfectly.
    Maybe you have already met “Dave” the multitool ;)?! He has been SUPER helpful!!
    (Next update I will post another photo of dave ;) !)
    Now just press in the bolt with the vice and because of the thread it slides in nicely and stays in place!
    Tadaa, the final result of the corner pieces on the frame, In total there are 4 pieces!
    Also you can see the result of painting :) !
  8. storm-83
    storm-83 Minimodder
    7 Nov 2014
    Nice progress, i like where this is going!
  9. Combatus
    16 Feb 2009
    OMG how thick is that steel!!! You go girl! :D
  10. NameAlwaysInUse
    NameAlwaysInUse What's a Dremel?
    11 Dec 2014
    Look sick! =)
  11. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    I hate steel,you get a 'well done' post just for that.
  12. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    This are some maad skills keep it up :)
  13. FAT
    19 Mar 2013
    Thanks!! Hope you will like the eventual outcome also ;) !
    Haha, yes, it is a LOT of steel ;) !
    Thanks :D !
    Haha, thanks ;) ! If you really hate steel than 'well done' feels like a big compliment! (next one will be made from acrylics, is that better or..worse?)
    Great :D ! Will do!!
    Super long update coming up!!!!
    But first… ;)
    Took me some time to post a new one, I’ve been working on my jewelry collection. I had a big jewelry exhibition and everything worked out very well!
    here are a few pic’s of the jewelry and presentation! (the casemodding skills came in quite handy with the presentation) !
    that said…. lets add some pictures :D!
    Here you see how the corner pieces are attached to the frame. First we drilled holes in the steel and made some thread….again…. ;)
    In the last update you saw the corner pieces for the frame. Here you can see how they were made.
    Neatly finished and all!
    To screw on the window we used standard bolts and customized them, so they can be screwed in and removed easily by hand.
    Mass production ;)
    Before and after
    Acrylics for the window.
    Dave in action… ;)
    Window for the frame, the safety foil states on until the build is done (…one learns from ones mistakes ;) )
    Next update more pictures on the wooden panels covering up the back of the frame.
  14. Cheapskate
    13 May 2007
    I may get banned for this, but d*mmned if I can let that pass...
    Is that your male partner making the big nut while you take pictures?
  15. babydragon_64
    babydragon_64 What's a Dremel?
    14 Jun 2016
    ...just joined the forums...love the build and your jewellery looks fab ��
  16. FAT
    19 Mar 2013
    Correct :D ! That is Tenzin working on the Lathe, he even made the picture ;) ! He works for a silversmith who has this awesome equipment, like a proper Lathe!
    We do have a lathe of our own workshop but that one is especially for wood and metal spinning (what we did with the FLUX NUC Case).
    Super handy if you have friends and colleagues who have different equipment :D !
  17. FAT
    19 Mar 2013
    another update on….
    Hardware it is!
    For the cooling of the build we used a Nepton 240 from CoolerMaster. Ofcourse we had to tweak it before it could be used in the build. The space for the cooler is quite limited.
    Thats why we choose a AIO so you don’t have to add a separate pump and reservoir. The tubes on the AIO are positioned in a way that they stick out to the front which is not really convenient in this build. So we decided to upgrade the aluminium radiator with a copper one and adjust the position of the tubes :) !
    The patient; a Coolermaster Nepton 240M
    Ok…there it goes… ;)
    Everytime I see this i have to think of.. 'We void your warranty' ;) ...
    Under this rubberplug there is a screw with a rubberring that we need to make a new fill port in the new copper radiator
    New radiator and better :D!
    Coolermaster fans on the new !
    Here you see the first version of the fill port! We drilled a hole on the bottom and glued on some extra metal with M4 thread.
    Works well, but could be better. The next try was a bit different from the one before.
    Step one is cutting the screw to the right size so it doesn’t block the water flow.
    This time the fill port is located in the fitting, so it is richt on top of the radiator and facing the top of the case.
    Step 2. is making a facet with a vile on the topside of the fitting.
    Step 3. Drilling a 1,5mm hole.
    Step 4. drilling the hole again with a 3,2mm drill
    Step 5. Ofcourse…making thread (what else..) M4 because that is the size of the CM screw ;) !
    En thats it!
    And don’t forget about the rubber ring!
    Next update more :) !
  18. NameAlwaysInUse
    11 Dec 2014
    That's brilliant :D
    Ps there is some stuff from Swiftech, like the CPU Pump block :D
  19. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    You are doing something wrong if you build a computer and haven't voided a few warranties. Nice work.
  20. FAT
    19 Mar 2013
    Thanks :)! Actually it is coolermaster, the Nepton240. we used it to make a modded version.
    True... :clap: and thanks :D !
    The frame is ready now we don’t need to weld anymore. So we can drill some holes for mounting.
    and ofcourse…making thread again ;) !….
    The panels we use to cover up most of the case are made of wood. They all be covered in black self adhesive foil with a kind of 'sandpaper look’ texture.
    These are the panels under the lasercutter.
    the first parts glued together.
    Luckily we have enough steel ;)!
    This is where the GPU will fit in!
    Behind the radiator there is a opened up part where the air can go through.
    Test fit with the MSI 980ti
    Drilling the holes for the pci express cable.
    Motherboard standoffs
    Spray painting all the corners and edges, on top the self adhesive foil.
    Just a sneak peak how we will finish the foot ;)!
