News AMD tweaks Radeon R9 Fury X cooler noise
Discussion in 'Article Discussion' started by Gareth Halfacree, 8 Jul 2015.
  1. Gareth Halfacree
    4 Dec 2007
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
    ..this is why you should NEVER purchase the first batch of new design hardware.
    Just be patient and let others be the Beta testers, I've learnt my lesson the hard way.
  3. IT Troll
    IT Troll What's a Dremel?
    27 Aug 2009
    "the specific pitch/sound in question was largely reduced through adjustments to the sound-baffling adhesive compound in the pump"
    So they glue-gunned it to reduce (but not remove) resonance? Is that what their customers deserve? I think potential customers would want to hear that they had "overhauled the pump" or perhaps "upgraded key components". Great PR job AMD!
  4. Mr Evil
    Mr Evil What's a Dremel?
    17 Apr 2015
  5. IT Troll
    27 Aug 2009
    Interesting link. So an AMD whiner got so furious with the noise that he dismantled his card!
    It does seem that the noise is caused by a combination of coil resonance, badly applied glue and component contact with the pump cover.
    A simple solution might be to insert some soft dampening material between the pump cover and pump.
  6. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
  7. DrTiCool
    DrTiCool Minimodder
    14 Jul 2010
    Does Fury X really need WC setup? Is it running so hot that those 3rd party air coolers wouldn't handle it?
  8. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    It's not just the heat that's the reason for WC, if you keep temperatures down you get less current leakage and that gives you the option to use less power or have more performance, basically it gives you more headroom.
  9. Harlequin
    Harlequin Modder
    4 Jun 2004
